Results 1 to 10 of 11
Thread: 3.0 v6 cambelt/water pump
    Sep 2011
    preston
    Default 3.0 v6 cambelt/water pump
    hi all, im new to the site having just bought a signum 3.0 cdti.
    my question is the cam belt is due to be changed and was wondering if its worth changing the water pump while the car is in bits? ive had previously z20let powered cars and was always advised to change the water pump with the cam belt because the are quite common to fail. just wondering if its the same with the 3.0 v6?
    car has covered just over 100k
    cheers in advance
    water pump isnt run by the timing belt on the 3.0 cdti
    its run by the aux belt
    as your at 100k id definately be changing timing belt and tensioner
    Sep 2011
    Winsford, Cheshire
    When are the belts due on this engine type? I have a 46k V6CDTi, 06 reg, no idea if belts have been done or if they need to be done.
    Sep 2011
    preston
    cheers for that. i've already got a cam belt kit inc rollers, tensioner and obviously the belt. it'll be getting a full service
    i think i read the cam belts are due 8 years or 100k . i could be wrong tho
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Water pump is driven by the gears inside the engine, so no real need to change that unless there's a fault. Cam belt needs doing every 10 years or 100k miles.
    Sep 2011
    Ireland
    is the 1.9 the same or is the waterpump driven by timing belt
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    As celes has said run off gears inside vx say no need to change unless fault.
    It's 1.5 hour job for timing belt kit.
    It's another 3 odd hours to change water pump
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    On the V6 CDTI it is recommended that the valve clearances are checked when the cam belt is changed, I think thats a 5 hour job.
    Regular Member Eirik's Avatar
    Aug 2009
    NORWAY/Kristiansand
    Is it necessary to check/adjust the valve clarence on this engine, I know they say you should do this on some engines, but usually there is nothing to adjust at all, but some engines definitely needs it...
    But it's a bit old fashioned to need valve adjustment, i thougt all newer engines had hydraulic valve lifters/tappets...
    wirral
    31 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    These engines have spacers mate and really do need checking
    As mentioned it's a big job. It's over an hour of just removing electrical components fuel lines etc before you can even get to front rocker.
  1. Water pump / Cambelt / Pre-cat downpipe
    By pthres in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 23:22
  2. Just had cambelt & water pump done
    By aps in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:46
  3. Cambelt & Water Pump
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 00:48
  4. 3.2 v6 GSi cambelt and water pump
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2010, 20:07
  5. cost of cambelt and water pump?
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 16:15
z30dt cam belt
