Thread: 1.9cdti 150bhp 55 plate vectra power steering stopped operating
    Sep 2011
    West Yorkshire
    Default 1.9cdti 150bhp 55 plate vectra power steering stopped operating
    Hi guys, recently serviced the throttle body on my vectra and whalst removing the allen key bolts, unbeknown to me there was a stray wire coming from the battery which the heat shrink seal had pulled loose from, exposing it. The screw driver then arked on this wire causing a spark. (like a numb idiot i'd forgotten to disconnect the battery)
    upon refitting throttle body after cleaning, and starting engine the power steering warning icon came on the dash and power steering is non operational. Consulting the owners hand book led me to a number 9 fuse in the fusebox right hand engine side.
    Multi meter tested this and its ok. There must be other fuses in the system relating to the electro power steering, does anybody know where they are located???????
    Power steering was fine before this nightmare! Tried to sort one problem and got another one, typical!
    Any help would be appreciated, cheeers
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Id check all fuses in the car, there is athe fuse box in the engine bay, and one in the n/s of the boot, there may also be one at one side of the dashboard.
    if all fuses are ok, id try disconnecting the battery for an hour, then reconnecting it and try again, failing that you may need to find a garage that can read any dtc's from the EPS module and try deleting any dtc's or resetting the EPS memory.
    Sep 2011
    West Yorkshire
    Cheers cobra, its sorted now. Turned out to be a 80amp fuse in the relay to the battery that had melted in half! Quick fix thankfully.
    Also how do you close threads when the problem is resolved????
    New Member sp1977's Avatar
    Nov 2009
    Warrington
    Default Help
    [QUOTE=Whiteknight841;1624639]Cheers cobra, its sorted now. Turned out to be a 80amp fuse in the relay to the battery that had melted in half! Quick fix thankfully.
    Kellogg does anyone know where the 80 amp fuse is located?
    New Member TomCliff's Avatar
    Mar 2012
    stockport
    hi i have done the exact same thing cleaning my throttle body, where was this fuse?
  1. 1.9cdti 150bhp 55 plate vectra idle speed problem
    By Whiteknight841 in forum Engine & Drivetrain
    Last Post: 21st January 2015, 07:55
  2. Power steering stopped working
    By SongBird in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2012, 17:08
  3. Vectra C 52 Plate Power Steering Problem
    By Nath79 in forum Troubleshooting
    Last Post: 8th February 2011, 14:28
  4. Loss of power issue (1.9CDTi SRi 150BHP, Vectra C)
    By Big Sie in forum Engine & Drivetrain
    Last Post: 20th April 2010, 17:46
vauxhall vectra power steering problems
my steering has whent stiff on my vectra 55 plate
vectra c 1.9 150 bhp power steering fluid where is it in engine bay
vectra 1.9cdti steering problem
vectra power steering fuse
vectra c steering relay
2005 vectra 1.9 cdti power steering light came on and steering gone stiff
2005 vectra 1.9 cdti power steering problem
power steering has stopped working on my vectra c
vectra c loss of power steering
power steering fuse vectra c
vectra 1.9 cdti power steering problems
power steering problems on vauxhall vectra
vauxhall vectra 1.9 cdti power steering stiffer
opel vectra c power steering fuse
vectra c power steering relay location
powwr stearing light on 1.9 cdti vectra
vectra c pas
power steering failed on vectra
vectra 150 cdti steering problems
06 plate vectra sri cdti 150 bhp 0 -60
vectra 1.9 cdti sri 150 power steering
vectra cdti power steering fuse
power steering failure on 05 vectra sri 1.9 150 bhp
vauxhall signum cdti 2007 power steering failure
