Thread: servicing
    Regular Member mattbrad30's Avatar
    Jul 2011
    West Midlands
    Default servicing
    Hi everyone my vectra has got a service this friday iv not had a service with vauxhall before is there any pointers or anything to look out for can i trust them with the car.
    Its having a large service costing £172
    What will that servise include my car is the 1.9cdti 120
    Quote Originally Posted by mattbrad30 View Post
    Check the front section of the Service Book, this should list what will be included, based on age and mileage
    Ask the service assistant for details of what the service will include, and this should match what you expect
    Also ask them what oil they will be using, it should be GM-LL specification
    The OE service will be oil, oil filter, and pollen filter (depending on age and mileage may also add air and fuel filters)
    Visual inspections and check of brakes, steering, and suspension
    If you are staying on the premises, then put the alloy wheel lock in your pocket, during the service they should report they could not find it
    Finally, check the receipt and make sure you get a copy of the service schedule
    Again, check the receipt for the oil used
    Jul 2011
    West Midlands
    hi thanks for the info my cars a 55 plate with 80k on the clock it was last serviced at 42k iv not long had the car
    Glasgow
    If its went 40k miles without a service and is now on 80k miles it needs everything done. Engine oil + filter, air filter, pollen filter, fuel filter and i would also do a coolant change and a gearbox oil change and on that mileage your timing belt will need replaced.
    Jul 2011
    West Midlands
    thanks for that i did ask the woman at vauxhall what would be done but she wasnt that helpfull tbh
    Glasgow
    I would make sure you know exactly whats included in the price before you head over with the car, even if it means calling them again and asking to speak to someone with more knowledge.
    Jul 2011
    West Midlands
    thanks mate i will in the morning
    Quote Originally Posted by byebyeitsagsi View Post
    VX don't list a schedule for coolant changes, but it is recommended at 10 years
    For this engine the gearbox oil should only be required if it is an automatic, I've only ever had manual and never had a gearbox oil change on any
    Would need to check the cambelt interval for this engine, as I understand it the later engines were 100K miles / 10 years
    If you had advised them the car was on 80K miles / 6 years old then the quote should have taken into account all the items required
    Presumably the car is out of warranty, so you could easily swap to the Masterfit Service and ask for all additional filters (pollen, air, fuel) to be replaced
    I assume you are using a VX dealership as the car is under a Network Q warranty, but there is then an issue over the service book gap which should have resulted in the car being serviced before being released to you
  1. Servicing
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2012, 19:27
  2. Servicing
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 13:45
  3. Servicing
    By Ben999 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2009, 14:43
  4. servicing
    By stuart bigboy in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 10:23
  5. Servicing.
    By bobby_rstevens in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 12:13
