Thread: Changing tyre sizes..
    Regular Member bigdave1701's Avatar
    York
    Default Changing tyre sizes..
    I currently have 215/50/17 fitted and am intending changing all 4. I know the recommended alternative is 225/45/17 but what would happen if i were to fit 215/45/17 instead?
    Sep 2009
    Audley STAFFS
    looking on a tyre size calculator,, the difference is 3.2% it will make your speedo read LOW, ie, with 215- 45s your speedo will read 2.2 mph SLOWER,
    11 Post(s)
    As the 215/45/17 isn't the alternate recommended size, you'll need to inform your insurer for starters.
    York
    But that would be true for any size other than the standard 215/50/17 wouldn't it as that is the only size recommended by the manufacturer. AFAIK 225/45/17 is only recommended by forum users to give the same radius as standard.
    Full Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Ive just got 4 falken ze912 225/45/17 fitted for £348, really happy with them compared to 215/50/17
    11 Post(s)
    Quote Originally Posted by bigdave1701 View Post
    The 225/45/17 is given as the alternate size in the Vectra / Signum handbook.
    The 225/45/17 isn't the same rolling radius as the 215/50/17. It's a -1.93% diffference.
    The 215 has a radius of 323.4 mm
    The 225 has a radius of 317.15 mm
    That's why the speedo will slightly over-read with 225/45/17's fitted.
    i.e. you'll be going very slightly slower than what the speedo is indicating.
    If you plug the sizes into a tyre calculator you'll see the differences.
    York
    Cheers.
    Sep 2010
    will make your arch gap look bigger... even tho only slight in radius.
    11 Post(s)
    Quote Originally Posted by chewy71 View Post
    Hardly noticeable, if at all.
    You're talking 6 mm difference.
    225/45/17 - fitted to the front:- http://img42.imageshack.us/i/16052009528front.jpg/
    215/50/17 fitted to the rear:- http://img42.imageshack.us/i/16052009529rear.jpg/
    (note to myself:- I really must update those photos sometime with a 225/45/17 tyre on the rear as comparison.)
    Sep 2010
    Well ... I notice it.... it's the same as having brand new tyres to completely bald ones. 12mm or half an inch overall diameter on the whole wheel / tyre
  1. Which tyre sizes
    Last Post: 5th October 2012, 00:42
  2. Replies: 3
    Last Post: 23rd April 2012, 17:20
  3. tyre sizes
    By marc7 in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2010, 23:41
  4. tyre sizes
    By chrissri82 in forum Handling & Braking
    Last Post: 4th June 2009, 12:59
  5. Tyre sizes
    By hopkinson06 in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2009, 20:18
