Results 1 to 10 of 21
Thread: Possible Oil Pump failing???
    Sep 2011
    Stockton on Tees
    Default Possible Oil Pump failing???
    Hi all, just got myself a Vectra C the other day, got the 2.2 Dti, 93k on the clock, elegance model, so all the toys, got it cheap as it had a Egr fault, which i was ok with, and im currently sourcing a new one, BUT....... tonight driving around, and stopped to pick up my mate and the oil light flickered erraticly??? Searching around the net and im led to believe this could be the start of my oil pump dying?? but i cant find a new oil pump on the net anywhere and obviously motor factors are closed now till monday
    Any suggestions to what this could be or whether i am facing the nasty job of sourcing a oil pump and replacing it?
    Thanks in advance
    Dan
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    How old is oil in it?
    Could do with getting oil pressure tested. As it could just be the switch
    Sep 2011
    Stockton on Tees
    I have no service history with it so im unsure, would it be worth doing the switch and an oil service on it? theres no increased engine noise which i know some people experienced, :S baffling me cos apart from it being in limp mode due to the EGR valve it runs sweet as a nut
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Just change the oil mate.
    Put some in run it for a week. And then change it agen. Should remove any sludge etc then and more than likely cure problem
    Sep 2011
    Stockton on Tees
    So do an oil change this week and then again next week? might as well do the oil filter while im at it,
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yes mate that's what I'd do. This week stick some cheap oil in.
    Then drop it next week or after 100 mile or so.
    Then change oil an filter for good quality stuff.
    At least then you'll no you've got good decent fresh oil.
    So if it happens agen you can get it pressure tested
    Sep 2011
    Stockton on Tees
    Cheers buddy Appreciated
    Sep 2011
    Stockton on Tees
    Well ive done an oil change on it, with some falcon 5w30 semi synthetic oil today, couldnt find my socket to do the oil filter, so ill do that with the good oil, would i be right in saying the oil pressure switch is located on the sump? theres two plugs on the sump and i can only think of one being oil level and one being oil pressure?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yes usually around the sump mate yes.
    Sep 2011
    Stockton on Tees
    Cheers pal, ill change it when i do the second oil change or i might lose too much oil with it being on the sump,
  1. possible alternater failing?
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 18:32
  2. Battery Failing Maybe
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 17:03
  3. Wipers failing.
    By izonoky in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 23:08
  4. Failing Handbrakes ...(Recalls)
    By The-Bandit in forum General Chat
    Last Post: 3rd February 2008, 22:13
  5. cdr2005 failing
    By tarandy in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2006, 20:13
