Thread: Uneven Wear On Rear Brakes
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Uneven Wear On Rear Brakes
    They have worn the passenger side out to the metal (and destroyed the disc ) but drivers side has a good 30% left?!
    What would cause this?! Got the pad and disc set from Vxl but was up to £91.80.
    Just a PITA that we are off to Aberdeen tonight and wont be back until late tomorrow so will have to use the wife's car for work and get a garage to change them on Monday.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Stuck slides more than likely are to blame for the uneven wear.
    Is it the original discs and pads?
    If so, then 5 years is excellent and outstanding
    Uneven wear on the rears is very common, due to the Traction Control
    I have never had a set wear evenly on the rear, where Traction Control is fitted, and it is even worse on the 3.0 V6 CDTI due to the ESP-plus
    However, if you have regularly been checking the wear and it has suddenly become uneven then it would suggest a sticking or worn caliper, or seized handbrake cable
    On my previous Mondeo the uneven wear was traced to the handbrake cable, the warranty paid for a new rear calipers, handbrake cable and assembly, and new pads and discs
    I also had two sets of pads and discs refunded to me, confirmed as excessively worn due to a manufacturing fault
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    sticking rear calipers are very common on the vec-c's
    think you can get an exchange unit form Vx from around £60 to the trade
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    mine had sticking calipers at 18 months and 20000 miles
    good job it was under warranty
    Tain - Easter Ross
    Back passenger and front drivers seem to have more wear and more dust than the others?
    What could cause that brake circuit to wear more?
    Tain - Easter Ross
    Verdict: Caliper. ot the replacement for £60 but the garage was checking the braking pressure and a metal brake pipe (one above the fuel tank?) burst so got to get that fixed now too.
    And before any assumptions are thrown around, I 100% trust the mechanic doing the work, he has been a family friend for a good number of years and would not just make stuff up!
    So, new rear pads, discs, NSR caliper and some new brake lines. Hope the bill is not TOO big!
  1. uneven and serrated rear tyre wear
    By veclee in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2012, 02:28
  2. Strange uneven rear tyre wear!!
    By maximus8425 in forum Troubleshooting
    Last Post: 2nd October 2011, 09:40
  3. uneven tyre wear on rear
    By croado in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 19:12
  4. Uneven rear brake wear
    By Wingnut in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2009, 20:51
  5. Major Uneven Wear on Rear nearside Tyre
    By jamieclarke in forum Suspension, Wheels & Brakes
    Last Post: 7th June 2007, 19:22
