Thread: Where to earth?
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Default Where to earth?
    Can anyone suggest a good place in the boot to earth my amp?
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    the bolts that hold the rear seats in is a good place thats were mines is earthed
    There's the factory earth point behind the plastic rear boot panel..
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by Gsi3.2
    On what panel? cheers
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    i found there was a good earth point just below the light cluster. i had to remove the plastic trim that GSI3.2 was referring to, i also removed the floor panel and the boot trim where the first aid kit should be kept. once i removed all of that i found there was a bolt with 2 earths already connected, i think its a 10mm bolt.
    Good Luck!
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Quote Originally Posted by Elite2.2DTi
    Good Luck!
    Thats what i used for my amps also, except the drivers side one but same difference
    Quote Originally Posted by Matt21385
    It's actually stud welded to the rear panel of the car..
    you need to remove the black plastic panel that fits around the boot catch and stretches across the back of the car.. it just pops off by pulling forward, then up..
    then you will see some brown and white leads connected to ring terminals, being clamped down by 10mm nuts.. this is the factory earthing points for the back of the car..
    Got my towbar wired into mine..
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Found it! Thanks guys
  1. Bad earth
    By dezzyb66 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 15:32
  2. Earth/ GND
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2011, 20:28
  3. what on earth
    By ant6566 in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2010, 20:01
  4. amp earth
    By sristeven1 in forum Electrical & ICE (including SatNav)
    Last Post: 8th March 2009, 02:07
  5. What on earth do I mod first
    By Coastie in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2007, 15:20
earthing vectra c 2005
