Thread: Help
    Jul 2011
    UK
    Year : 06
    Default Help
    my mate has a clio 2001 1.5dci its knocking a lot on driver side front and leaning down slightly is this spring f****d am replacing it 2moz but just want no if could be out else
    Jul 2011
    UK
    Year : 06
    Anyone
    Regular Member UltraVec's Avatar
    Jun 2011
    Dublin
    I'm no mechanic but from the knocking noise I would have said CV joint especially when turning but with the car leaning slightly it could be a busted/damaged shock absorber?
    sorry cant be off more help, impossible 2tell without a proper look.
    Don't iron out a combination of problems, could be more than 1.
    Jul 2011
    UK
    Year : 06
    It knocks wen just moving littlest bump in road and knocks like a rubble
    Jun 2011
    Dublin
    Could be a range of things to be honest, anything that's not right can cause a knocking or rumbling noise.
    I'd try narrow it down to exactly where the noise is coming from.
    Maybe the wheel bushing(could be just dry, no lube) or drop link pins, i dunno but try shaking/rocking the suspected wheel and listen for where it originates.
    Even using the old screwdriver against the ear job may narrow it down4 ya.
    I'd imagine its the spring/shock absorber(maybe fluid leak?) if the cars tilted on the flat tho.
    Hope you sort it.
    Jul 2011
    UK
    Year : 06
    Cheers mate yer its tilted on a flat maybe thinking strut shocker has gone
    Jul 2011
    UK
    Year : 06
    Spring has a crack on bottom of it so that must be the cause
