Thread: lumpy idling
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Unhappy lumpy idling
    hi all i sprayed carb cleaner into my air intake took it for a run and now it has lumpy idling. when i sprayed it in i had a friend rev the engine so i did everything in check. please someone help. i have the 2.0t thanks
    East Ayrshire
    Trim : SRI XP1
    I take it all the sensors are reconnected and pipes are tightened up? Might just need a good blast to clear it. It can sometimes dislodge a little bit of dirt that needs to get blown out the system
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Either or you have possibly dislodged some soot and oil; and the combination of the two is choking the engine in the manifold a bit at idle.
    Insignia VX-Line Nav CDTI 170.
    Mileage : 55000
    I presume there is an "Air control valve" on the side of the throttle body. You might had dislodged soom "soot" as said above and it might has gone insde that.
    I used to have to remover the "Air control valve" off my old Vectra B and give it a good spray with carb cleaner, that used to do the trick. There were Two holes in the side (looking down from the inside) of the throttle body where I was able to spray carb cleaner into it too, if I did not have the time to remove it.
    Nov 2010
    doncaster
    i have this or seem to have on my 1.9 cdti 150 after i cleaned egr and boost sensor any help fellas cud just be me
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    found out what the problem is. i had a diagnostics test on it and its misfiring. spark plug renewal. cheers guys
  1. Idling Cars
    By Dezza in forum General Chat
    Last Post: 2nd December 2008, 22:41
  2. idling rough
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 16:21
  3. 2.2 idling
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:00
  4. Idling
    By Daywalker in forum Engine & Drivetrain
    Last Post: 10th May 2008, 08:23
