Results 1 to 3 of 3
Thread: system check/aaaah!!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default system check/aaaah!!
    How or what can i put in-line to stop power bleed through from the bulb/light check system!, I thought id solved my intermittent peeep from the parking sensors but its still the same, Ive found that with a meter there's a power/heartbeat of 2-3 volts going to the sounder for the sensors, When i part the brake & reverse wires from the system the meter drops so is there anything i can put in line to the sounder/bleeper to stop this!!.
    Regular Member FatboySteve's Avatar
    Bedfordshire
    No expert but, is it 2-3 volts going to it which shouldn't, but is enough to make it make a noise ? and is usually 12v when on ? if so maybe a resistor, so the 2-3v is not enough to make it sound, but a resisted 12v is.....if that makes any sense whatsoever lol
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Exactly! that's what its doing, So you reckon i need a resistor/s in-line from the brake & reverse feed wires, If you put a meter across the bleeper it shows a 2-3v heartbeat from the system check, This must upset the sensors & cause a peeep that sounds like a short or similar, The best thing about it is the voltage only shows in the bleeper plug/wires.
  1. Does the Vec C have a self check system...
    By Chunklamb in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2012, 00:33
  2. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  3. Check control system
    By bertxuk in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2012, 10:09
  4. Any one got how teo guide to check air con system?
    By warren77 in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 26th August 2011, 21:03
  5. Anyone in North West with tech 2? to check SRS system.
    By sri andy in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2009, 19:58
