Thread: changing the front passenger door
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Question changing the front passenger door
    I have a replacement front passenger door to fit to the wife's vec. It has come with out the glass so I will have to swap that over along with the rest of the bits..
    Does anybody have any tips on what i need to do to make life easier when doing this job?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    have a second person there!! Once them hinge pins come out the door gets bluddy heavy
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Do you not just have to undo the small torx screw and lift the door off the hinges?
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    guessing at hinge pins, they are pins on vec 'b's not seen them on 'c's lol. was trying to blag it..
    Jun 2009
    South Coast
    6 Post(s)
    removing it will not be an issue, its all in the Haynes manual. I take it I can leave the lock but just swap the door modules and switches etc along with the glass. I was just wondering if their was any tricks to make the glass and motor swap easier..
    Seems i need to go and buy some pop rivets and a hand rivet gun or whatever they call them..
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Shame you're not closer Nige, I've got a rivet gun and rivets here you could have used. They're about £20 or something for a set in Halfords.
    Jun 2009
    South Coast
    6 Post(s)
    well that job is done and all is working fine..
    Now tips i can leave for the next guy that the Haynes manual does not mention. Whilst two men is useful i changed the door over on my own, a helper would have been useful but i am quite a strong chap and had no problems.
    Get yourself a Haynes manual before you do this...
    You will need a rivet gun and some 4mm rivets (about 10 will do). The Halfrauds £14.99 kit with its selection of rivets will do this for you. You only need this if you are moving the electric window mechanism from the door.
    When you have take the interior panel off connect up the window switch again as you will need to lower the window a little to get to a retaining screw on the glass runner.
    After changing the door you do not need to change the locks over (unless you are changing the drivers door) but you will need to change your door module over. Do not close the door until you have tested the new locks on your module by pressing your door lock button on the key fob or the master control on the drivers door first.
    Just ask if you have any questions...
  1. How to fit Front Passenger Side Door glass
    By thehoq in forum Bodywork & Interior
    Last Post: 14th March 2013, 15:59
  2. Replies: 32
    Last Post: 2nd January 2013, 02:18
  3. Passenger front door?????
    By DKitch in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2009, 21:54
  4. need a new passenger front door
    By ade in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2008, 10:25
