Thread: vectra c 2.2 sri dti smoking ??
    Sep 2011
    clacton on sea
    Default vectra c 2.2 sri dti smoking ??
    Hi all,
    i have a vectra c 2.2 DTI sri, its done 140,000 miles and runs and drive a dream,
    only on start-up from cold and after car has been left for a few hours it bellows out white smoke for about 10 seconds then stops
    is this a common problem? what can cause it to do this?
    any help would be great as i havnt had the car long and dont really wanna spend alot on it if its going to be hassle!
    cheers in advance,
    steve
    Regular Member tditony's Avatar
    durham
    Vehicle : 2007 sri xpnav
    Trim : sri xpnav
    Engine : 1.9 150
    white smoke is unburnt diesel, could have leaky injectors just dribbling a bit but it aint cheap to find this out im afraid hope this helps
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    How long does the engine usually take to fire?
    Sep 2011
    clacton on sea
    little update on this, is not white smoke its blue, and its using oil !
    are the turbos a problem on these engines? mine has done 140,000 miles ?
    cheers
    steve
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    When was the oil last changed and what grade is in it? Mine had this very problem (albeit it wasn't for 10seconds) and it was because I was using Mobil 1 0w-40 oil. i changed to Castrol magnatec 5w-30 and it cure the problem
    Sep 2011
    clacton on sea
    i change the oil last week for 5/30 fully synthetic, thinking of trying something slightly thicker as its a high mile'r ?
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    i use 5/30 and mine has now done 180435 miles
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I have 10w/40 semi synthetic in mine and apart from a little blue puff on startup, it doesn't burn any - mine's done onver 200,000 miles. A thicker oil may help but if it's only really chucking out smoke when it starts up then I'd suggest getting a garage to do the valve stem seals. They'll be leaking oil into the cylinders. Don't worry about the turbo yet. If it's visible when driving the problem is most likely somewhere else.
  1. vectra cdti 1.9 120 smoking
    By stj in forum Engine & Drivetrain
    Last Post: 17th February 2012, 18:51
  2. vectra c 2.0 dti smoking
    By daveybuc in forum Engine & Drivetrain
    Last Post: 4th May 2011, 21:07
  3. vectra 1.9 cdti 150 smoking
    By blakester9 in forum Engine & Drivetrain
    Last Post: 16th March 2011, 19:23
  4. vectra sri turbo smoking
    By jambo114 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th July 2008, 19:41
  5. Smoking Vectra POLL
    By wrightgj in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2005, 18:23
1.9 cdti bellows white smoke from cold start
vectra 2.2 sri smoking
2.2dti chucking out smoke
