Thread: Wireless problem
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default Wireless problem
    the wee man has tried to connect his ipod up to the modem (wireless)
    tried it myself..after putting in network key..after a few seconds it says "unable to connect" to blah de blah...
    any ideas ?
    cheers peeps
    Regular Member nick-v2.2's Avatar
    Nottingham
    try turning your modem off then back on
    firewall, try turnin it off to connect, but remember to turn back on again....
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Also watch the type of encryption in use on the router (ie. WEP or WPA etc), or if you have changed the network password.
    Reason being, if the ipod has previously been used on the network, and either the encryption type or the password have been changed, you'll probably have to "forget" the network on the iPod and then re-add it as it will be remembering the old settings.
    Full Member
    Bristol
    My mate had a problem the oother day. tried connecting hi palstation and his Ipod with wep. That will not work wpa is the only thing that will work.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    WEP sucks don't use WEP encryption.
    I can crack a WEP key easily with Backtrack and limited knowledge!
    Regular Member UltraVec's Avatar
    Jun 2011
    Dublin
    If you still can't gain access then check the back of your modem 4 the original network key, if its there then use the full reset button on the modem and re connect with the network key on the modem.
    Once setup, change it all.
    can try gaining access to your routers setup by http://127.0.0.1
    Also as above change Wep to WPA psk 2 preferably.
    Also hide your SSID(Name) from being broadcast.
    Hope it helps.
    Edinburgh
    127.0.0.1 is the loop back address for your PC. You'll need to do an ipconfig and look for the default gateway ip. That's usually your router.
    Full Member
    South West
    Will probably find the routers address is more like 192.168.x.x
  1. Wireless Lan
    By The Gas Man in forum General Chat
    Last Post: 13th March 2012, 08:02
  2. wireless adaptor 360
    By Dwabo in forum Games Room
    Last Post: 21st November 2009, 14:37
  3. No wireless
    By garvey in forum The 'Off Topic' room
    Last Post: 15th December 2008, 23:37
  4. Wireless + Vista + Acer = Problem ... Help !!!
    By Bainie in forum General Chat
    Last Post: 16th November 2007, 20:47
  5. Replies: 12
    Last Post: 29th November 2006, 10:17
