Results 1 to 10 of 18
Thread: Catch Tank Clean As A Whistle?
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Catch Tank Clean As A Whistle?
    Sorry to make yet ANOTHER thread on the Oil Catch Tank, but I fitted my catch tank a few days ago, and the pipes are spotless, done about 100miles, thought there would be at least a haze of oil inside the pipes,
    Have I put it in right?
    Got it going in for Cambelt wednesday and don't want the garage thinking I'm a wolly if I've put it in wrong?
    Sodding Typical on Sea
    Mine follows that pattern but vents to atmos and I have a patch of oil on the garage floor under the filter I fitted so mine is defo passing oil mist. I have covered around 14,000 miles though
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    it could be that the flow of air is just carrying the oil through as normal when i do mine i was gonna try putting some oil in the bottom to help grab/condense the oil mist, not sure if it will work but might be worth a try
    Regular Member benny's Avatar
    Feb 2006
    dudley
    wonder if the oil seperator might be doing its job .....just a idea mind .......
    Quote Originally Posted by benny View Post
    In my two Vectra's the pipework was coated with wet oil residue prior to my pipework modifications, cannot comment on others and would go so far as to say if my cyclone did work as it ought I would never have made the modification.
    Mar 2011
    Wirral
    The pipe that I cut into that comes out of the oil seperator was coated in oil on the inside of the pipe, might just re-route it to atmos as I was also thinking the same as Penfold said, feels like a wasted job!
    Regular Member Innes's Avatar
    Plymouth
    Is the tank set higher than the breather pipe? If its set higher then the condensation and vapour isn't going to make it to the tank. The tank needs to be set as low as possible.
    Oct 2006
    southampton
    15 Post(s)
    Put some stainless washing up scrunchies in to condense the mist....
    Mar 2011
    Wirral
    I'd say it's about level with the breather,
    I will get some scrunchies today when I go to the shops and see if that helps, cheers guys
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by Innes View Post
    if it's high it condenses in the pipe and runs back.
  1. oil catch tank.
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 00:32
  2. Oil catch tank.
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 7th March 2012, 15:21
  3. Oil catch tank
    Last Post: 23rd December 2011, 16:04
  4. Oil catch tank
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 21:08
  5. Oil Catch Tank
    By JSYSH466Y in forum Petrol Engine related
    Last Post: 28th February 2009, 12:11
clean oil separator on vectra c
cleaning out oil separator z19dth site:www.vectra-c.com
