Thread: calipers vs. discs
    Regular Member ferooo's Avatar
    Oct 2010
    Slovakia
    Default calipers vs. discs
    Hi,
    I have V6 3.2 Vectra C and I want to upgrade my 302mm brakes to 314mm. Questions are:
    this is caliper for 302mm disc?
    this is caliper for 314mm disc? (I already saw this caliper on 302mm disc )
    So I just want to know if I can use this caliper with 314mm for sure?
    Or this same looking big calipers was made for 302, 314 and also for 345mm disc and they are different (but same looking)?
    ps: sorry for my english
    Feb 2011
    London
    The yellow ones looks like the calipers you would want for the 314 conversion. If you wanted to change to 314 you will need new calipers and mounting bracket and disk
    Oct 2010
    Slovakia
    So when I will buy calipers which look like the yellow one, I have 100% sure that they can be used with 314mm discs? This is what I need to know for sure before buying them.
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    yes, the yellow ones are meant for the 314mm discs
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Mileage : 000
    I have those calipers on mine, which has 314m/m disc,s.
    Oct 2010
    Slovakia
    caliper for 314 and 345mm disc looks almost same. So what about yellow caliper (on picture above) on 302mm disc? I already saw that caliper on 302mm disc, but I don't know if that caliper also can handle 302 and 314mm disc or if that caliper is different as 314 caliper, but same looking..
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    the correct calipers for 302 discs do NOT look like yellow ones, only the 314 and 345 calipers have that particular spring clip
    Oct 2010
    Slovakia
    ok, so caliper which looks like the yellow one above is 10000% for 314 (eventually for 345), not for 302mm?
    Jan 2006
    Hornchurch
    Quote Originally Posted by ferooo View Post
    yes but to fit the 314mm caliper on the 345mm you need to file them up a few mm a bit
    Oct 2010
    Slovakia
    for now I just need it for 314. Maybe later I'll star thinging about 345
  1. 314mm Calipers and Discs
    By husky in forum Parts for sale
    Last Post: 2nd January 2011, 14:49
  2. GSi 3.2 314 mm Calipers & Discs
    Last Post: 12th June 2009, 12:54
  3. Replies: 1
    Last Post: 21st October 2008, 15:11
vectra c calipers which discs
