Thread: Wheel sizes what do they mean?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Wheel sizes what do they mean?
    I have been looking for a spare set of wheels for some winter tyres.
    And it seems to be a bit of a minefield.
    I have seen some alloys that say 6.5J X 16".
    What does the 6.5J bit mean
    What is the offset and the PCD?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    6.5 J is the width. You need 5 * 110 pcd. And I think offset of 38 to 42
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    And bore size 65.1
    Jun 2006
    North West
    Thanks for more numbers
    But what are they?
    16" I know, its the outer diameter of the wheel
    6.5 is the width of the wheel (thanks s_zigmond)
    but what does the J part mean on the width?
    5 * 110 pcd ?????
    offset 38 to 42 ????
    bore size 65.1??
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    PCD. 5 is the number of bolts and 110 is the distance between said bolts
    Offset is the distance from the center of the wheel to the mounting plane
    bore size is the hub diameter (so how big the hole in the middle of the wheel is)
    Also ive always been told the J means nothing and refers to the shape of the wheel rim
    Sep 2010
    PCD stands for Pitch Circle Diameter and is relative to the circular centreline of the 5 bolt holes which differs from manufacturer to manufacturer
    Offset as s_zigmond said is the dimension from the face of the wheel to mounting face - I got this wrong once and my alloys sat inside the car by some 20mm!! handled like it was on ice!!
    bore size is the dimension for the centre spigot hole in the wheel
    Jun 2006
    North West
    OK thanks. That helps.
    Is a wheel width of 6.5 OK for a Vectra C?
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by Marky View Post
    Yup if its a 16
  1. Wheel sizes
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 02:09
  2. Wheel Sizes..?
    By pjames.79 in forum Styling
    Last Post: 5th March 2008, 16:09
  3. wheel sizes
    By customaccent in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2007, 23:46
  4. wheel sizes (again!!!!)
    By markspark in forum Handling & Braking
    Last Post: 31st January 2006, 23:42
  5. Wheel sizes
    By 24vElite in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2005, 13:15
6.5J X 16 means
what does 6.5j mean on wheels
what does 6.5 j mean
wheel 6.5j mean
what means 6.5j in a wheel rim
