Thread: Z20Net Timing chain
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Default Z20Net Timing chain
    Well got motor back from garage yesterday after going in to get the whole timing chain/tensioner/guides and cogs which i have had in the garage for a while now i got call from head mechanic half way through the day saying the rattle you have is not the timing chain ...we have had the motor out and done all the tests and inspection we can think of and its definitely not the timing chain .... so off to the garage had a meeting with head and 2 other mechanics after a lengthy debate they are thinking its the DMF or another part of the clutch ... so im no further forward in tracking down whats causing the noise or getting it fixed ...parting words from gaffer was let it develop and then we will be able to fix it don't get me wrong i can actually drive the car without this rattle occurring as it only happens in second gear when in low revs and you give it some stick if i drive like Sunday driver its OK .... anyone had anything like this before?
    Jan 2006
    Dalriada
    Does sound like a transmission issue phil, but it also sounds like its going to be a ****** to diagnose!
    I assume you got the chain replaced anyways?
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by Steven View Post
    it was checked out and was said to be ok ....i did have the tensioner changed about 3 years ago because of this issue and did not help
    Regular Member PORKBALLS29's Avatar
    Epping
    I used to have the same problem with my old pre face 2.0T Siggy and was all ways led to believe that it was the tensioner, it kind of twittered and rattled at low revs if you put your foot down.
    Jan 2006
    Dalriada
    The tensioners usually only tweet when its cold do they not?
    Epping
    Mine used to tweet any time The car was in too higher gear and lower revs if you know what I mean.
  1. Z20NET timing chain
    By vectra100turbo in forum Engine & Drivetrain
    Last Post: 21st April 2012, 08:58
  2. Z20NET timing chain
    By vectra100turbo in forum Vectra C / Signum Troubleshooting
    Last Post: 18th March 2012, 23:12
  3. Z20NET Timing Chain Parts
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2011, 10:10
  4. 20T Z20net Timing Chain Help
    By alanwh in forum Engine & Drivetrain
    Last Post: 21st March 2011, 10:59
