Thread: Going to take my car in for Battery test, could be alternator failing
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Going to take my car in for Battery test, could be alternator failing
    Hi guys,
    Not sure what's up with my car this past month could be the battery or the alternator. Its a 07 1.9 CDTI 150
    Car did not start on two occasions. Jump started fine instantly.
    Going to take car in to have free battery test.
    Voltage measurements
    Engine off the voltage measures - 12.0V
    On ignition the voltage drops slightly it measures 11.8V
    Engine running voltage measures 14.0V (Blower off, Stereo off)
    Engine running voltage measures 13.8V (Blower on, Stereo on)
    Hope is not the alternator at fault. Car has done 65K. No battery warnings whatsoever, car drives fine once started. Just the bit of starting up, worries me lol, especially on cold days .
    Regular Member Geo77's Avatar
    Sep 2009
    North Yorkshire
    Your readings would indicate that your alternator is working fine.
    So prob your battery or something else.
    Starter motor?
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by Geo77 View Post
    Starter motor?
    Thanks.
    I'm thinking it might be the battery, is just on odd occasions or cold conditions not getting enough cold cranking amps to turn the engine over.
    So thats why i'm going to test the battery first.
    Jun 2011
    Elland
    I have had dealings with a chap at South Yorkshire Battery and the equipment he uses to test battery and alternators gives a 'straight up' diagnosis. The modern diagnostic equipment is spot on m8 and should put you right
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by hebblemarine View Post
    Thanks. I hope its just the battery.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Very strange still trying to find out what it is, i took my car to several tyre places for free battery test, every one of them say noise on battery when testing, so then i took it to auto electrician for test, he said the battery need replacing from his readout. Anyway my battery once went flat after two days without use, so i did a battery test on it, where i disconnected the battery for two days then reconnected it two days after, and car started up perfectly. hmmm scratching my head again. But the annoying thing is auto electrician said i need new battery. Disconnected all my mods thats linked direct to the battery.
  1. Battery Failing Maybe
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 17:03
  2. Alternator or Battery
    By Jamie in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 21:30
  3. Alternator or Battery???????
    By Griff72 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2011, 19:02
  4. Alternator or Battery?
    By callist in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2010, 20:24
  5. Henry to miss world cup for failing drugs test.
    By crespo in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2010, 18:34
