Results 1 to 10 of 17
Thread: Split pipe
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Default Split pipe
    I went to clean my boost sensor today as I noticed a recent lack of top end grunt and since I've had the car a year now I thought I'd see if it was that.
    I popped the bonnet and found a 1 inch split in the pipe just before the boost sensor.
    Part number is 55556525. I've asked my local dealer for a price and laughed at him when he said it was £84 including VAT. AutoVaux want £72 for the same thing.
    My question is, since I only need the top hose, where can I get silicon hoses at a reasonable price?
    Regular Member bigdave1701's Avatar
    York
    Would some form of rubber bonding agent not work?
    Sep 2010
    6 Post(s)
    Trim : SRI
    I'm tempted to try it until I can get a replacement.
    Regular Member Innes's Avatar
    Plymouth
    I made my own. See my sig. It gets interesting from page 6
    Plymouth
    Just remembered my membership has run out so no sig.
    Here is the link. This is for the DTI but depending on the shape of your hose you could probably make your own
    http://www.vectra-c.com/forum/index.php
    Jun 2011
    Elland
    @ lee
    also remove your engine cover and check the rigid pipe (that your split flexi goes to). Check that the union between the rigid pipe and the throttle body is secure (mine had worked loose) and carefully check just below the jubilee clip between the throttle body and the rigid pipe for splits (mine had). New piece of rigid pipe on order fron VX 70£ Grrrr!
    Sep 2010
    6 Post(s)
    Trim : SRI
    Thanks for the info, thing is though, the car still flies, I'm working from home tomorrow so will check the rigid pipe.
    I don't want to buy the whole intercooler return pipe when I don't need it all. I'll look for your post regarding the pipes Innes (your link just goes to the forum root mate).
    Plymouth
    Sep 2010
    6 Post(s)
    Trim : SRI
    Thanks Innes, where did you order the bend and tubing from?
    Sep 2010
    6 Post(s)
    Trim : SRI
    Found the AP Automotive link from Innes' thread, so I have remove the pipe to get the internal size only to find it's 63/64mm reducing to 53/54mm, nearest 90 degree elbows are 63mm down to 51mm. VX don't like giving us easy options do they?
    Will the pipes give a little if places in boiling water, don't laugh I never used silicon hoses before?
  1. fuel pipe split.....cdti
    By mark the hat in forum Engine & Drivetrain
    Last Post: 13th November 2016, 12:06
  2. Split pipe? Which one is the intercooler?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 3rd January 2013, 21:59
  3. split pipe
    By pacman696 in forum Engine & Drivetrain
    Last Post: 6th June 2011, 21:04
  4. Split pipe or is it worse?
    By cookie in forum Engine & Drivetrain
    Last Post: 19th May 2010, 22:14
  5. Anyone had a split air intake pipe from MAF?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 11th June 2009, 11:07
