Thread: EGR Reprogram
    Oct 2009
    northwich
    Default EGR Reprogram
    Howdy all, fitted a brand spanking new (not recon) EGR to my 1.9cdti (120) the other day and the car now hesitates even more than before i replaced it. Can anyone advise if there is some reprogramming of the ECU required at Vauxhall as I have tried two new valves, both having the same result. Drives ok ish when EGR is disconnected. At wits end with it now!!
    Aug 2011
    denny
    Hi mate apart from the 2 13 mm bolts how do I get the egr off to blank it cheers
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Is swirl valves ok?
    Oct 2009
    northwich
    Don't think the 120 has swirl valves, I beleive its only the 150
    Wales
    Swirl valves on 120 only.
    Software update needed by the sound of it. The following courousy of Lesj..
    Field Remedy: 2149
    Subject: Engine Z19DT/Z19DTL - Jerking in certain rpm range
    Models: Engines: Option:
    Astra-H ...2006,Zafira-B ...2006,Vectra-C 2004...2006 Z19DT| Z19DTL,Z19DT| Z19DTL,Z19DT| Z19DTL only C9 system and 2 valve engines
    Complaint: Customer complaint about engine jerking between 1500-2500 rpm, mostly with 2nd or 3rd gear engaged.
    Cause: Problem is related to a EGR software deviation.
    Production:
    Remedy:
    In case of customer complaint reprogram ECU with an improved software.
    The new software will be available as of CW30/2008 via TIS2WEB
    (version 8.0) (Only vehicles with MY 2006).
    Modified software for Vectra/Signum, MT, with and without DPF,
    as of MY 2004:
    Available as of 27-Jul-2009!
    FunctionalGroup: J - Engine
    Complaint Group: 19 - Poor Engine Driveability
    Trouble Code: None
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    I believe it's the 150 that have swirl valves, not the 120?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by DeeBe View Post
    100% correct - the 120 doesn't have them at all.
  1. reprogram key
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2012, 21:09
  2. Signum horn and steering wheel buttons not working after key reprogram
    By designit in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2010, 00:02
  3. Anyone recommend a dealer to reprogram my CID
    By acorndave in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2010, 19:46
  4. How to reprogram a key fob
    By lukesignum in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2010, 11:39
  5. bsr ppc reprogram ??????
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2008, 23:10
