Thread: radio auto volume at speed
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default radio auto volume at speed
    i dont know its propper name but its sodding annoying!..
    its that thing that turns the radio UP when you drive faster and i hate it
    is there any way to disable it so the radio volume stays at the level i set it at
    11 Post(s)
    Speed Dependent Volume Control (SDVC)
    Yes, there is a setting somewhere.
    What stereo, as it might vary between models.
    On a CCR2006 for example you have to press and hold down the tuner button until it beeps. The display then shows something like "SD VOL +2". Adjust the number by pressing the < or > buttons (from 0 to 5, IIRC). When it displays "SD VOL +0" the auto vol control is switched off. To storre the setting, press and hold Tuner again until it beeps.
    On a CD70, it's in the volume sub menu.
    I find setting it to number 2 is about right. Just automatically raises the volume slighty without it being deafening.
    Jul 2009
    Brighton
    On the CD70, I think you hit the SETTINGS button and it AVC or something like that.
    I find it really useful when setup correctly. Try to play with the settings first before setting it to 0.
    Full Member Big Sig's Avatar
    Its probably all explained in that papery thing that came with the car. Unless you don't have one?
    Feb 2011
    Selby
    Setting SD VOL 2 works best for me too, on a CCR2006. Just starts to increase it at 60mph when the wind/tyre noise starts to intrude a little. Any more and it starts to get a bit too loud compared to the road noise.
    It does say quite clearly in the manual how to change it - which you can also download in PDF form online.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    havnt got one or id of RDFM...obviousley
    forgot to mention its a 2005
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    just sorted it !.... it was a press of the tuner button until it bleeped and then i set it to two, then pressed tuner again.... job done
    cheers all.
    al.
    Feb 2011
    Selby
    You should be able to download the manual from http://www.opel-niedersachsen.de/radio.html
    11 Post(s)
    Just looked. Not mentioned in the V5C log book anywhere.
    Regular Member Geo77's Avatar
    Sep 2009
    North Yorkshire
  1. speed volume
    By vectra_ in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2010, 14:00
  2. auto volume
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2009, 15:02
  3. CD70 - How do you adjust speed related volume!
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2009, 17:46
  4. radio volume
    By sanny512 in forum General Chat
    Last Post: 25th February 2008, 23:25
  5. Speed Dependant Volume Control
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2006, 16:02
auto volume control vauxhall
