Thread: squeek on startup and shutdown
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default squeek on startup and shutdown
    i get a slight squeek like im throttling a budgie (hahahaha)...
    it also sounds like belt squeal but its only for about 1 second or less on startup ans shutdown..a mechanic said it could be the bottom pulley rubber starting to seperate but iv no idea..
    the aux belt is pretty much solid and i dont get any belt squeal at all appart from start/shutdown...
    any ideas?
    al.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds as though your aux belt and or tensioner is knackered. The bottom pulleys don't give any warning they just fail
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by Al 22 dti View Post
    any ideas?
    al.
    I had the same problem it started last winter. On investigation my tension pulley had failed (I’ve got a pic of my old one that failed somewhere, I'll post it) I changed the belt and tension pulley
    I think I got a new one from the bay of e for around £30 0r £40 squid?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    cheers steve.... piks would help.
    al.
    Trim : Sport
    Engine : Petrol
    al.
    It failed where the bolt goes through the plastic bush/insert. The hydraulic piston had also seized.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    cheers steve... il have one asap... is it a big job and is there a how2?
    al.
    EDIT...** just found the how2 lol**
    Trim : Sport
    Engine : Petrol
    al.
    I dunno about the how 2 mate. I just removed my airbox, jacked the drivers side up, placed it on an axel stand, removed the D/S wheel, wheel arch and bottom plastic trim/sh@t shield. Then it's a case of two torq bolts. The top one is hard to get out a s there aint a lot of room.
  1. Vectra C Total Shutdown!
    By Littleted in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2011, 23:39
  2. engine shutdown
    By robbie1944 in forum Engine & Drivetrain
    Last Post: 16th December 2008, 10:28
  3. CD70 colour startup/shutdown screen
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 23:04
squeek on shutdown
