Results 1 to 10 of 11
Thread: Feedback needed: EBC Brakes
    Regular Member Alex the Russian's Avatar
    Jun 2011
    Moscow, Russia
    Default Feedback needed: EBC Brakes
    Hello,
    anybody used EBC 'turbogroove' discs and their 'red stuff'?
    The biggest plus for me is that this kit is to be fitted on stock without any modifying.
    Is there any minuses?
    Redditch
    I have the discs but green stuff pads and they work really well
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    I have used green stuff in the past, and found them very good.
    The first time you use your brakes in a morning with the red ones they won't stop very well at all, however very good when up to temperature (more for track days than road usage).
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by mcpitman View Post
    The first time you use your brakes in a morning with the red ones they won't stop very well at all.
    I used to run the discs and red pads (314mm brakes) and never had an issue...yes they do work better after a lil warm up but even cold they out perform the standard stuff.
    Jun 2011
    Moscow, Russia
    Quote Originally Posted by hagga View Post
    what d'you mean - a little warm up?
    just several brakings when started moving?
    Regular Member aps's Avatar
    cheshire
    Vehicle : Vectra C Sri CDti 150 (satnav)
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    And if you get drilled/grooved discs youll take a little time getting used to the hissing when breaking
    Sutton Coldfield
    Vehicle : Siggy Sports Tourer
    Trim : SE - But fully loaded!
    Engine : 160 cdti
    Used to run these on my Mondeo ST, it stopped very well, but the grinding noise each time you applied the brakes was too much!
    IMO go for the green stuff pads not red, too hard
    kingswinford
    Quote Originally Posted by Alex the Russian View Post
    As in they worked better than standard when cold but as they warmed up they were loads better..hmmmm for example..if slowing down at speed you'd feel the braking increasing without putting anymore pressure on the pedal. for a standard upgrade they're good... I've since upgraded my brakes to..well lets say my rears are 325mm.... and I still use red stuff pads all round.
    kingswinford
    Quote Originally Posted by digitalinkjetman View Post
    I've never tried green..... but to clear things up....found this(on migweb)..seems black to yellow the lower operating temps are the same and only the max temps increase...apart from the blues which are track use monsters lol..
    I'll be going for yellows next
    Jun 2011
    Moscow, Russia
    thanx, guys!
    I've ordered turbogroove discs and red pads
    hope that they will work fine when winter comes...
  1. brakes question help needed please
    By rickeys16v in forum Suspension, Wheels & Brakes
    Last Post: 12th December 2012, 00:13
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Advice Needed : Siggy 2.0t Front Brakes.
    By Envy in forum Handling & Braking
    Last Post: 12th August 2011, 09:24
  4. Urgent help needed RE: Rear brakes
    By tempo in forum Suspension, Wheels & Brakes
    Last Post: 10th June 2007, 23:03
  5. Feedback needed
    By Andy in forum Billing 2006 8/9th July
    Last Post: 7th March 2006, 22:12
