Thread: Z22YH Fuel Pressure Regulator
    Regular Member Paul_NI's Avatar
    Mar 2011
    Northern Ireland
    Default Z22YH Fuel Pressure Regulator
    Hi All
    in an effort to try and find out what was causing my lumpy idle, I disconnected the EGR valve, no difference, the disconnected the MAF, still no difference.
    I then convinced myself I could hear ticking from the engine and my chain had slipped and i need a new timing chain... ok maybe a bit extreme with only 27K on the clock.
    Anyway under further listening by me an a proper mechanic, we believe the ticking is coming from the FPR this is supported by the fact that the hose connecting it back to the fuel pump pulsates quite strongly.
    Is this meant to happen? This is apparently a new FPR fitted by VX 3 months ago, but I do believe it caused my Siemens fuel pump to fail and I do not want it to do the same with my nice new 2 week old Continental one
    Paul
    Regular Member cphaza's Avatar
    Hertfordshire
    Worked on a few z22yh's, never seen that before. Does the pulse match up with the misfire?
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by Paul_NI View Post
    Paul
    I was advised that this does happen by Vx when i put mine in fora chain inspection, there findings state this on the "receipt"
    Mar 2011
    Northern Ireland
    HI Spenny
    thanks for the replay
    Just to clarify:
    Did you take your car to VX beacuse you could hear a ticking noise?
    Did your car have a rough idle?
    Did VX say the ticking sound was the FPR and it was normal operation?
    Paul.
    Blantyre
    Hello Mate,
    I took it as i thought there was a rattle comming from the chain, i took it to Nationwide(Halfords) first, they said no issues, i then took it to Vx, as i wanted a second opinion, They checked it over and did advise me that the noise i could hear was coming from the FPR, and this was normal operation
    I have the receipt somewhere mate i will stick it up and show you once i find it
    Mar 2011
    Northern Ireland
    Thanks spennny
    could you feel the fuel return pipe pulsating?
    I am now assuming that the fuel pressure is not steady and although not casuing a misfire, is at idle starving the engine of fuel?
    or maybe I need to take the throttle body off again? Maybe I just need to get my ass in gear and get the intake manifold off and lean it properly? maybe the fuel filter needs changed? maybe the cat? maybe the chain? maybe a sensor lol
    Blantyre
    Pmsl mate, you sound like me
    Mar 2011
    Northern Ireland
    surely these cars cant be all that bad lol
    I drove a hyundai Santa Fe 2.0 CRDi for 8 years without it missing a beat!! Surely a VX is better?
    I forgot the Coil pack... and maybe the thermostat
    Blantyre
    There not bad, this site makes you hear all sorts
    Keep them well serviced, new oil and filter every few 1000's miles as i do, and fingers crossed
  1. Z22YH Fuel Pressure Regulator
    By johnmac in forum Engine & Drivetrain
    Last Post: 4th December 2015, 20:35
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. For Sale: 2.2 direct Z22yh Fuel Pressure Regulator
    By davidlewis24 in forum Parts for sale
    Last Post: 7th April 2012, 17:59
  4. For Sale: Fuel Regulator Vectra c 2.2 direct z22yh
    Last Post: 3rd August 2011, 20:24
  5. Fuel Pressure Regulator
    By gdallas in forum Engine & Drivetrain
    Last Post: 7th July 2011, 12:58
z22yh rough idle
z22yh fuel pressure regulator
