Results 1 to 10 of 14
Thread: F35 Gearbox Fluid Change
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default F35 Gearbox Fluid Change
    Hello all,
    Following the How2 on the F40 fluid change, I want to do this on my 2.2DTi (F35) gearbox. Reading the Haynes manual, and TIS cd I bought, they both say it takes 1.9 litres of fluid.
    They both suggest the procedure (shortened) is to drain, remove the level plug, and refill via the reversing light switch aperture until the fluid reaches the bottom of the level plug aperture. Now in the real world would you do it like this, or would cut out removing the level plug aperture and just stick in the recommended 1.9litres of fluid?
    Also, how fiddly is refilling, would I need to remove the battery tray etc?? Any suggestions or experiences are gratefully received!!!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You won't get every drop of gearbox oil out so yes take the level plug out and then drop the car on the jack till it's sitting level.
    You won't need to remove the battery box but you will need to move the glow plug relay/vacuum pipes out of the way....they just slide up off of the mounts on the battery box
    Aug 2010
    Derbyshire
    I followed the "how to" and never removed the battery to refill or get at the fill plug.
    Mine's the F40 box on the CDTi 150. Sounds like yours is a different arrangement.
    I used a piece of garden hose with a piece of copper tube on one end into the fill hole, then a funnel on the other. Fill with the car level on the ground. Make sure you can remove the fill/level plug first, that is before you remove the drain plug, for obvious reasons.
    Mick
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Good luck getting the drain plug out! Right pain in the arse.
    Cheshire
    Quote Originally Posted by cont1204 View Post
    i modified a 90 deg Allen key for the F35 it worked really well.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by paul667 View Post
    So is the drain plug an allen key fitting? I was going to say, there's one under there I believe to be the drain plug, but no where in the manuals says which one it is. I've assumed it's the plug I've circled in the attachment, can anyone confirm?
    Mileage : 000
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by ed taylor View Post
    Thanks Ed!!!
    Mileage : 000
    On mine it is as the "drawing" above. Yes the drain plug is very close to the chassis.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    As Edd says, it is RIGHT next to the subframe/chassis leg, very little clearance. It can be done though!
  1. Auto Gearbox Fluid Change
    By Homer in forum Engine & Drivetrain
    Last Post: 15th November 2012, 10:50
  2. Gearbox fluid question
    By Gubmint Agent in forum Engine & Drivetrain
    Last Post: 27th November 2011, 20:02
  3. Gearbox fluid change
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2011, 19:24
  4. gearbox fluid leaking ?
    By pro auto valet in forum Engine & Drivetrain
    Last Post: 25th October 2010, 19:59
  5. Gearbox/clutch/brake fluid change-TOMORROW!!
    By nikroc in forum Engine & Drivetrain
    Last Post: 23rd February 2010, 22:49
f35 gearbox on 1.9cdti
