Thread: Any thoughts on this?
    Sodding Typical on Sea
    Default Any thoughts on this?
    I have 4 Pirelli P7 215/50 x 17 tyres on the car all fitted and balanced at the same time and the car drove wonderfully smoothly and had no vibrations or strange wobbles.
    The tyres are not directional but assymetric (marked outside on the outside,,,) I did the diagonal swap front n/s to o/s rear and vice versa.
    On the motorway at 70 ish I get an intermittant vibration, it comes and go's!!!
    I checked torque on the studs I looked for a thrown weight but it looks fine, so apart from one wheel perhaps not being im-properly balanced back in May, why would this show up as there was no problem or vibration from the back-end before.
    Never come across this before anyone got any thoughts or theories?
    Regular Member Guss's Avatar
    Aug 2011
    West Malling, Kent
    Thumbs up
    hi...
    how old are your tires? whats the tread wear like. i have found with some tires once you hit the visual tread wear nodes"for want of a better word" thats the raised rubber bit inbetween the tread this can cause vibrations..
    Russ
    Tyres are about 7mm rear and 6mm front before the swap round (they were new in May )
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    you will always feel an imbalanced wheel thru the front as you'll feel it thru the steering wheel.
    may be worth getting the fronts rebalanced.
    Devon
    Quote Originally Posted by Derek Mc View Post
    If it's intermittent then it sounds like one or both steering arm balljoints are worn. Both mine were worn, and when I replaced them the vibration disappeared.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    I know it may sound daft Derek but what road were you on at the time? Reason I ask is that I got terriblle vibration on the road past the Heritage loch in EK. And also the A726? EK expressway as you pass the top end of Blantyre, and a slip road as you come out of Righead ind est at bellshill. The vibration was so bad I thought the wheel s were falling off, turns out it was just a very bad road surface.
    3.2 v6 Signum and loving it
    This is a known issue on part-worn tyres, which are then rotated
    If you have crossed them across the car, the issue can be worse
    As above, when rotating tyres it can be prudent to see if rebalancing is required, the usual symptom is vibration at constant speed
    The issue is often not felt when the balance on a rear tyre is incorrect
    As you probably already know I rotate my tyres as they wear and quite often I have to have the front tyres (previously on the rear) rebalanced
    It is just pure luck, but the most usual cause is higher mileage than normal on the rear or simply one or more of the weights falling off (very common on alloys)
    Hi, thanks I did wonder about the crossing of them hence reversing their previous wear patterns, so might get them re checked.
  1. Thoughts on DPFs.
    By Signum-Steve in forum Engine & Drivetrain
    Last Post: 28th May 2011, 15:32
  2. thoughts
    By markf09 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2011, 20:53
  3. Having Second Thoughts!!!
    By Fireyfella in forum Styling
    Last Post: 4th December 2009, 17:38
  4. Thoughts please?
    By DoncasterGSI in forum Styling
    Last Post: 13th June 2008, 23:44
  5. Your thoughts on this mod ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2008, 08:23
