Thread: Adjusting rear brakes?
    Aug 2010
    Leeds
    Default Adjusting rear brakes?
    Is there a manual adjustment on the rear brakes?
    Or is the caliper wound back the pedal pumped for the brake to automatic adjust?
    Car had pedal travel yesterday and been for a service at vx for £99.00 comes back to it and great pedal nice and firm.
    Hand brake seems a little firmer, i know on shoes brake the rears are adjusted to set pedal travel and handbrrake would have been wound off the re set up after.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The trick is to not have the hand brake on when you pump the brakes back up after a pad change. Change the pads as normal, winding the piston back in as you do and then pump the brakes back up using the pedal making sure the hand brake is off all the time (chock the wheels obviously).
    If you do it with the hand brake on, the brakes won't pump back up as firm.
    Aug 2010
    Leeds
    I know the hand brake is not on when pumped.
    But i have NOT had a brake set changed i have a firmer pedal so some adjustment has happened from where?
    Barrow In Furness, Cumbria
    You can adjust the handbrake by removing the rear ash tray and tightening the cable. Don't think this would affect the normal brakes though.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    They will have serviced the brakes, cleaned and greased the slides, its amazing how much of a difference this makes if they have not been done for a while. Means the pressure on the each pad is the same now, meaning a firmer pedal. Did a mates Scenic, slides were seized, you could see how the pads had only been working on one side of the disc.
    Aug 2010
    Derbyshire
    What grease would you recommend on the sliders?
    Mick
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Copper grease bud.
    Aug 2010
    Leeds
    Had a nice drive yesterday and is more responsive and coasts much easier, i suspect i had a dragging brake they say 50% worn car done almost 17k.
  1. Adjusting the rear hatch
    By Derek Mc in forum Bodywork & Interior
    Last Post: 2nd January 2011, 22:21
  2. rear brakes
    By scottymartinXPSRI in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2009, 09:51
  3. Adjusting rear disc cover
    By grumpano in forum Handling & Braking
    Last Post: 6th June 2008, 11:04
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
