Results 1 to 3 of 3
Thread: dual air con running permenantly even when key is out
    Default dual air con running permenantly even when key is out
    right had 2 hours of solid rain this afternoon , got in the car to come home and put demister on , when i stopped half way home to go in a shop the fan for the air con carried on running
    i checked the drain under the bonnet and yes it was blocked so cleared and got rid of all the water
    but the fan has continued to run
    so have had to remove neg off the battery
    the question is .... is the fix the same as if the heater doesnt work on 1,2 &3
    http://www.vectra-c.com/forum/showth...=1#post1495923
    WGAF#5
    hi Mark ... hopefully the resistor will sort it ...if not then it may have shorted the cooling fan too
    hey dez
    thanks for the info
    the fan is running permanantly , so will have to wait and see
    hopefully its just the cheap fix
    just a pain having to remove the battery negative
  1. Anyway of running dual headunits?
    By weverall in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 00:29
  2. running with eml on
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2011, 22:40
  3. Running on oil
    By dunkymunky in forum Diesel Engine related
    Last Post: 18th November 2010, 08:34
  4. anyone running this box
    By Keithy in forum Tuning
    Last Post: 28th December 2009, 23:18
  5. running much better
    By monty1 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2007, 21:55
