Thread: 0003
    Dec 2010
    south wales
    Default 0003
    Just done the pedal trick on my siggy 3.0v6 elite and it's given me 0003 any advice or help would be great as i hope it won't cost the earth as things are tight at the moment. Thanx alot.
    spoons
    Guest
    Thats your Secret Service Reference Number... Moneypenny will be in contact shortly. Over and out.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    Apr 2011
    Southport
    Quote Originally Posted by spoons View Post
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    you done the fuel filter lately ?
    Dec 2010
    south wales
    Yes changed the fuel filter last week.
    Aug 2010
    Luton
    sounds like its not the right one or not working correctly did you have fault before you changed it?
    Dec 2010
    south wales
    Thanx disco dan it says fuel volume regulator circuit low, any ideares wot this is and how to fix it thanx.
    Dec 2010
    south wales
    Not sure if the code was up before i changed the filter, the filter is from vauxhall, it kept going into limp mode when pulling up hill with the caravan on, and when the tempt is up to 90 it cuttsout while ticking over,so i changed the filter to see but still cutsout sorry to go on a bit but really would like to get to the bottom of this problem.
    Aug 2010
    Luton
    think it might be a tech2 job then as when on tech2 you can see fuel pressure as it might be pump or regulator and you don't want to swap regulator if its the pump, In saying that did it only happen when going up hill? sounds like the gravity and poor pumping might be the problem how many miles is car/fuel pump
