Results 1 to 3 of 3
Thread: Banjo bolt size?
    Regular Member sheepish's Avatar
    Yorkshire
    Default Banjo bolt size?
    Hi all,
    Does anyone know what size banjo bolts fit the front claipers on a 52 plate 1.8 LS?
    My front pipes are corroded so I'll be replacing those... and I might as well replace the hoses and banjo bolts while I'm playing...errr... I mean 'fixing' it. And I might as well go for stainless...
    They're all 12mm mate - the kits from goodridge and Hel both come with 10mm on either the front or back so best to ring up when ordering and make sure they're right...
    Yorkshire
    Thanks Penfold!
  1. Power Steering Banjo bolt size
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2013, 12:32
  2. Turbo banjo bolt
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 27th July 2011, 10:05
  3. Banjo washer size?
    By rushy in forum Handling & Braking
    Last Post: 14th January 2011, 15:06
  4. Goodridge Braided hoses - Rear banjo size problem...
    By Penfold101 in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2009, 17:29
  5. CDTI Banjo Bolt
    By JamesG in forum Engine & Drivetrain
    Last Post: 1st February 2008, 14:17
banjobolt size vectra
vectra banjo washer size
