Results 1 to 10 of 28
Thread: traction control switch
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Default traction control switch
    can anyone tell me how i fit a traction control switch to my vectra c 2.2 dti elite please. and where can i get hold of 1 from? cheers
    North east HQ
    the easiest place to go is your dealer, part no.13138265 (£8.80 + vat), just pop out the blank below your alarm switch and push your new switch in. simple. NOTE the switches dont work on everyones car , it seems to be hit and miss, even if you do have TC. to check first, remove said blank and have a look if there is a blue plug at the back.if there isnt bad luck, if it is you might be in with a good chance.even if it doesnt work, it should light up
    Oct 2006
    coventry
    thanks i will have a look later then.
    Jun 2006
    teeside
    even if there is a blue plug it wont necessarily work, mine doesn,t on a 55 plate,but it does light up
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    I have the blue plug and mine lights up. I have ESP+ but the button don't work but looks better than a blank as doeas the sport switch
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    I think we sort of came to the decision if you have full can bus system (roller controls for stereo on steering wheel) it prob wont work. If you have the older semi canbus system it probably will work............
    Mileage : 000
    Mine is a 3.2v6 with ESP and is half canbus........ sadly the TC switch does not work on mine for some reason only Vauxhall might be able to answer..
    Oct 2006
    coventry
    it has got a blue socket so just been to vauxhall dealers.I forgot to take the part number with me, the guy behind the counter spent about 15 mins trying to find it on the computer system.so i had to go all the way back home to get the part number. gotta wait a couple of days for it as they dont stock that switch.
    Regular Member cameraman's Avatar
    Leicester
    I have the TC switch installed as standard with ESP option on my 1.9CDTI the switch doesn't light up on mine but the warning on the speedo comes on to tell you the TC is off..
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    i have the 2.2DTi Elite on a 03, and the TC switch works fine.
  1. traction control switch
    By Beavis in forum Parts for sale
    Last Post: 13th April 2008, 08:15
