Thread: 1.8 vvt
    Regular Member GoldenWonder's Avatar
    Durham
    Default 1.8 vvt
    Is there an ECU/software update that anyone knows of that might sort out the hesitation/overreving I get on my 2006 1.8 VVT in 1st/2nd gear?
    I find it really tricky in traffic to 'crawl' by holding the revs at 1100 or so (like when you're moving up a hill and balancing the car on the clutch and throttle) it seems to either drop down to 500 rpm or go up to 1500rpm with a microscopic movement on the throttle pedal!
    My wifes got a 1.2 Polo and thats a joy in the traffic compared to this as you can easily 'hold' the car on the clutch. I don't mean riding the clutch just getting a nice smooth pull away!
    Its probably the only thing that bugs me about the car at the moment and it seems like it should be easy to fix! I tried the airbox mod and if anything I think it made it worse. Air filters is lovely and clean as well!
    Regular Member nelly452's Avatar
    Aug 2011
    reading
    have you fitted the standard air filter back in if so try a k&n panel filter or pipercross it may help.
    Barrow In Furness, Cumbria
    I get this on mine as well. The only thing on the car that I don't like.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Our pre VVT Facelift Z18XE club has had similar symptoms since we bought it 5 years ago with < 4k miles on the clock which described in this thread...& which seems to have no permanent cure....Note my comments towards the end of the thread about the dealers response 'Blank Looks' when I described the symptoms....
    http://www.vectra-c.com/forum/showthread.php?t=62965..
    ....which got very little response at the time from the forum.
    Advise at best seemed to be ' Try this, That or the Other ' at a few tens of pounds a time...which didn't seem to offer a permanent cure.
    I've got used to it with this engine but my wife comments about it almost every time we go out in it....
    However...........
    A thread on here a while back & comments in it by vxr-jim about the 1.8VVT Z18XER may be of interest...
    http://www.vectra-c.com/forum/showthread.php?t=90644
    Durham
    Cheers for that.
    I had a read through that - even the ECU update doesn't seem to make that much difference from the comments!
    Looks like you can minimise it a bit with a better filter, updated software and thats about it - just a characteristic of the car I suppose. Wonder if its the same in the 1.8 VVT Astras?
