Thread: Enabling BC on CD40 Opera?
    Engine : 1.9 CDTi
    Default Enabling BC on CD40 Opera?
    Is enabling BC on CD40 Opera the same as doing it on the CD70?
    IE going up 1 variant in the coding?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    not in variant coding, but in "Code Index"
    eg it says 006 01 its just to chose/change it to 007 01
    Engine : 1.9 CDTi
    Thank you
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    There is a section in the display Variance Config, that selects the BC as being present.
    If this is not set as present, then the folder will not be shown at the top of the display. (Assuming that a GID is fitted).
    Incidentally, it can still be selected by pressing the BC button.
    If it is not enabled in the display, then when you turn the head unit off, you will get the time, date and temperature displayed.
    When you have it enabled in the display, you will get the range and MPG or L/100Km shown instead.
    But as said above - It is the Code Index that "Enables" the board computer.
    The variance config just affects how and when it is displayed.
  1. Cd40 opera... What does it have??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2012, 00:16
  2. Cd40 opera
    By Si-SRI in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2011, 21:50
  3. CD40 Opera
    By jonnye in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2011, 21:33
  4. cd40 opera
    By steve-wolves in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2009, 21:53
vectra c bc enabling
