Results 1 to 10 of 14
Thread: Strange electrical problem - please read & help.
    Birmingham
    Default Strange electrical problem - please read & help.
    Guys,
    The Siggy is getting what seems to me like a really strange electrical problem.
    I have noticed a couple of times that when I engage first gear and take off, the car almost wants to cut out (and has done a couple or times) and then if I stop and accelerate its fine. This happened to me on Friday and it actually cut out (usually on a warm'ish start may I add.
    I also noticed that my central display was slightly flickering. I had my mates in the car at the time and they said it was me and that the lights werent flickering.
    Anyway, same thing just happened now about 15 mins ago. I took off and it almost cut out on me. I kept it going and continued driving but now my central display is flickering lightly and the stereo keeps cutting out, almost as though someone is turning it on and off every 15 seconds.
    After about 2 miles of driving, its fine and the display stops flickering.
    No EML/problem lights. My first thoughts were alternator buts its had one about 6 months ago.
    What could this be.
    Please help. Winters coming, wife sometimes drives the car, dont want it getting stranded.
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Glasgow
    I noticed you said the alternator was done recently BUT i would check it is charging properly as it sounds like it could be that.
    Birmingham
    Quote Originally Posted by byebyeitsagsi View Post
    What and how should I check it?
    Bye bye Vec B
    - Hello Siggy!
    Glasgow
    That im not to sure off any mechanic will be able to check it with a multi-meter and tell you if its charging properly and it will take about 2 minutes.
    If it was a new alternator you should have a years warranty on it aswell.
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Check voltage at the alt and battery.
    Is it only when it's warm it's doing it?
    Sep 2010
    Cork
    Quote Originally Posted by Vaux-Man-G View Post
    You can check it using the following (with the engine running) on the following thread: http://www.vectra-c.com/forum/showthread.php?t=55096
    The voltage should be reading around 14.2, if the alternator is charging properly. My mechanic found that it was only achieving 13.8 and the provided an additional cable from the alternator to the battery. This solved the problem.
    I have an 06 Facelift CDTi (120) Vectra with a CD30
    Birmingham
    Quote Originally Posted by CritchvxD View Post
    Does it when its cold or slightly warm. When hot it seems OK,
    Quote Originally Posted by Seaghan View Post
    I have the pre-face Signum, its the one with the older style display. How do I get the secret menu on this?
    Bye bye Vec B
    - Hello Siggy!
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Just stick a multimeter across the battery with the engine running and everything electrical switched on (lights, heated screen, etc etc), if it's still making at least 13v then the alternators fine. Switch everything off and leave the engine running and re-check, it should then be up to 14v+
    Birmingham
    Quote Originally Posted by Ian-Highlander View Post
    Excellent, just need to find someone with a multimeter.Will report back soon.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Just had this checked from a local alternator and starter re-con place and the starter, battery and alternator are all fine. NOW IM LOST!!!!
    Bye bye Vec B
    - Hello Siggy!
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. Strange electrical problem regarding radio controls on steering wheel
    By eaglepva in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2011, 17:36
  3. Electrical problem
    By damm in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 11:57
  4. strange dash electrical fault
    By lee866 in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2010, 17:56
  5. Electrical problem please help
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 22:54
