Thanks Thanks:  1
Likes Likes:  1
Results 1 to 10 of 15
Thread: dash board/ dials not working??? :(
    essex
    Angry dash board/ dials not working??? :(
    hello, posting on behalf of a colleage who has a 2007 Vectra estate 1.9 cdti.
    interimttently, the dash dispaly (dials and warning lights) switch off/goes blank. everything else seeem sto continue working ok.
    remedy seem to be switch off and restart.
    length of time seem to be totally variable.
    any suggestions/fixes????
    local dealer-stealer is being very unhelpful and evasive.....
    any help gratefully recevied..... as they have two young children and his missues is now too scared to drive it!
    thanks in advance
    Dan
    Jan 2010
    wirral
    Had the same problem with mine. Theres a thread on here about it somewhere. If you open the front passenger door, you'll find a fuse board, there are two fuses which need to be looked at (I can't remember their numbers), I just removed them both and re-inserted them and this cured the fault. On the other hand, others with the same fault have had to replace the CIM and they ain't cheap.
    Jan 2010
    wirral
    The fuse numbers are 17 & 26, also worth checking/cleaning the ABS plug (under the bonnet)
  4. Thanks superstuper thanked for this post
  5. #4
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Yeah try the fuses in the dash, think it's # 17 & 26 (check that first) and re-seat all the blue one's in the fuse box in the boot. Other thing is to spray contact cleaner on the ABS plug contacts under the bonnet, and finally clean the contacts on the plug on the CIM itself.
    If you do all this and like me it still doesn't cure it, then you'll need a new CIM which aren't cheap as mentioned. Think it's approx £400 for CIM and a tech2 session at whatever the going rate is.
    I've lived with mine for 18months now, still annoying but that's life
  6. #5
    Regular Member bothyboy's Avatar
    Nov 2009
    Herefordshire
    I had this once (thankfully) cleaned fuses mentioned and not seen it again. But still concerned it could return.
  7. #6
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Fuses 17 and 26 infer an adverse problem linked to the Body Control Module.
    The actual fuse for the CIM module is Fuse 10.
    I always quote a whole rake of fuses to check as follows
    Fuses 7, 9, 10, 12, 17, 19 and 26.
    The other common cures have been
    1) check that all the steering collumn earth tags are secure and in good order
    2) Check and clean the pins in the ABS module connector plug
  8. #7
    essex
    thanks everyone! will pass on info
    Dan
  9. #8
    essex
    well..... hes just spoken to the garage, who reckon its the dash cluster.... and want £500 to replace and tech2 it!
    and.... best of all.... its not covered by his warranty
  10. #9
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Robsey View Post
    I remember reading on here that someone had cured theirs by running a separate earth lead from the CIM. I really should try this to see what happens.
  11. #10
    Admin plasma's Avatar
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by dankilbourn View Post
    depending on where you are in essex, IF it does need a new set of clocks, it should be no more than about £200 all in
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Dials not working!!
    By kev.whitehead in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2012, 17:14
  2. Instrument Panel Dials Not Working
    By mick mcm in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2010, 15:13
  3. dash board.
    By delboy2028 in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2010, 20:22
  4. Dash Dials keep going off !
    By bart1664 in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2009, 18:34
  5. Dash dials at 0
    By Tigger in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2009, 20:27
vauxhall insignia dashboard not working
vectra c dash lights not working
vauxhall vectra instrument panel not working
vectra dashboard failure
vectra c dashboard not working
vectra c instrument panel not working
vauxhall vectra dashboard lights not working
vectra c dash not working
vauxhall vectra dash lights not working
vectra c dials not working
vectra c clocks not working
vauxhall signum dashboard not working
vectra dashboard not working
vectra c instrument cluster not working
vectra instrument cluster not working
vauxhall vectra 2006 dashboard lights
https:www.vectra-c.comforumshowthread.php146373-dash-board-dials-not-working-(vauxhall vectra 150 sri no dash lights or dailsvectra c no dash lightsvauxhall vectra dash not workingvauxhall vectra c dash not workingholden vectra dashboard problemsvectra c dashboard fusevectra c dash problems
