Results 1 to 3 of 3
Thread: Pistons need changing if Valves have hit!?!?!
    Regular Member Coupe2T's Avatar
    May 2011
    Hampshire
    Default Pistons need changing if Valves have hit!?!?!
    Quick question, if valves have hit pistons, an the valves need changing, should the pistons be changed too!?! Or is there circumstances where the pistons would still be fine!?!
    Only asking as just had a repair on my Vectra and I've been told that valves have had to be changed as well as rockers as they broke but no pistons, seemed a little odd to me!?!
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Pistons won't always be damaged. It is possible to get away with it. Unless the valve breaks off and embeds itself in the piston or any serious damage happens to the top surface you'll be fine.
    Feb 2011
    Selby
    The valves are a relatively soft metal, quite thin too, compared to the big lump that is the piston. I've rebuilt countless engines over the years, and the worst damage I've seen a valve do to a piston is a bit of a scratch that doesn't affect running. Also the piston is being pushed by a big chunky conrod by the heavy crankshaft, whereas the valves are fed from the weedy camshaft (and rockers depending on engine), so they're always going to come off worst.
    What can do more damage though is if the valve head breaks up, and the bits of metal scratch the bores.
  1. Caliper pistons - which tool ?
    By Sparky67 in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2016, 02:11
  2. Egr valves
    By mon in forum Engine & Drivetrain
    Last Post: 9th November 2012, 21:34
  3. changing discs and pads, pushing pistons back.....
    By taffy bhoy in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2012, 22:33
  4. Pistons
    By GCusdin in forum Petrol Engine related
    Last Post: 21st May 2012, 12:29
  5. totating rear brake pistons but not going in - HELP!
    By circushead in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2010, 18:06
