Results 1 to 10 of 17
Thread: aftermarket stereo but want my bc working
    May 2011
    Derby
    Default aftermarket stereo but want my bc working
    hi ive got my jvc headunit left from Vectra b and want to fit it in my VC. I read somewhere that u can still have your Bc,i dont want to loose my mpg,miles remaining etc. and be able to flick between them, but u got to do it from stereo at the minute what to do when stereo is gone? thanks in advance
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Dependent upon Year of manufacture
    2002 to September 2004 (Half CAN Set-up). Buttons on the steering wheel
    You will need the Computer switch on the wiper stalk.
    This will need to be enabled via Tech 2, Vaux-Com or Op-Com
    October 2004 to September 2008 (Full CAN set-up). Scrollers on the steering wheel.
    The switch is for Half CAN only, so in this case, you would use the Scroller controls on the steering wheel.
    If you have a full CAN vehicle but no scrollers, then these will need to be fitted, along potentially extra wiring and Tech 2, Vaux-Com or Op-Com enabled.
    See this thread for how I upgraded my Vectra to Scroller controls.
    http://www.vectra-c.com/forum/showthread.php?t=107692
    Feb 2011
    Selby
    Without knowing what age your Vectra C is, or what model the original radio is, it's hard to know if you'll lose the ability to control the BC.
    For example, on my early 2004 Vectra, there are no controls on the radio for the BC (CCR2006), only the controls on the wiper stalk. This setup will still work with an aftermarket radio, you just lose the radio station name display from the BC screen. But if you've got no wiper stalk controls then you'll have to get a wiper stalk with them, and have it enabled with Tech2.
    On a full CANBUS car (2005ish pre-facelifts, and all post-facelifts) then the same applies, but with the steering wheel controls.
    gwent
    I got a aftermarket headunit fitted and is full canbus and I can still cantrol the on board computer with the steering wheels controls
    ijk571
    Guest
    Quote Originally Posted by wayne10244 View Post
    What loom / harness adaptor did you get?
    gwent
    My head unit is a kenwood and I brought the kenwood steering wheel control harness for it and I can change the time on the screen
    May 2011
    Derby
    Vectra 2005 55 plate, stereo CD30
    May 2011
    Derby
    how do you use scrollers do switch to BC, and flick beetwen options? because u said to use scrollers, i have got them but dont know how to use them, does it have to be enabled thru some software?
    Apr 2011
    Toulon, France
    Quote Originally Posted by RRadek View Post
    press in left scroller button then scroll up or down, then press it again to select. mine like that. easy
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by tanya_baby View Post
    My other half's motor is a full CAN-bus with CD30. Works exactly as above
  1. aftermarket stereo cut out
    By Allan-DTI in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 19:55
  2. Aftermarket stereo
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2010, 15:20
  3. Aftermarket Stereo
    By GazVXLINE170 in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2010, 07:16
  4. Aftermarket stereo
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2009, 11:39
  5. aftermarket stereo
    By stevietiger in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2005, 11:36
https:www.vectra-c.comforumshowthread.php146344-aftermarket-stereo-but-want-my-bc-working
vectra c bc
vaxhall does bc work on sat nav head unit
vectra computer board afterMarket
vectra stereo replacement
vectra c radio upgrade
fitting after market radio and still been able to use vauxhall display
vectra new stereo
Safety Harrison 31041
can you change the stereo on a signum and still use the steering controls
opel half can aftermarket stereo
vectra c preface radio upgrade
vauxhall vectra stereo
aftermarket stereo keep trip computer vectra c facelift
vectra c facelift trip computer with aftermarket head unit
can you.control trip computer with aftermarket stereo
how to upgrade signum stereo
astra h bc button with aftermarket stereo
vectra c radio replacement
vectra c aftermarket stereo
how to wire temp fuel screen in vectra c to aftermarket stereo
ccr2006 upgrade
will my display still work vectra c stereo
vauxhall vectra c stereo
aftermarket stereo not turning off Vectra C
