Thread: Headlights point to high
    Sep 2011
    Lancashire
    Default Headlights point to high
    I've had my 03 plate Vectra LS for two years it had passed it's MOT no problem but this time it has failed because the headlights are pointing up to much, the mechanic told me the headlights were held in position not by the metal holders but by the rubber caps, I got the clips that hold the bulb in position fitted them and it still failed.
    The mechanic reckons who ever had the car before me had fitted xenon bulbs didn't do it right and has put the headlights out of their correct position, the headlights don't move when I use the button on the dash that moves the headlights up or down, the is about a 1/4 of an inch play in both the headlights when I hold the bulb holders.
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    not sure what its like on pre face, mines facelift and before i put the motors in my new headlights there was a small amount of play. Just check the motors are attached.
    May 2008
    Tyneside
    My motors became disconnected and lights were too high. Here's a picture of the ball and socket connection, the motors are a baynonet fit. HTH
    http://i483.photobucket.com/albums/r...1/P8130352.jpg
    Sep 2011
    Lancashire
    Thanks for the help both of you hit the nail on the head, both motors have become disconnected, I will have a go at fixing them at the weekend.
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    no probs bud, glad i could help!
    Feb 2011
    Selby
    Don't forget you can adjust the headlight aim with a 5mm Allen key on the headlight units themselves. But it does sound like the motors aren't doing their job in your case.
    Normally those of us with pre-facelifts complain our headlight aim is too low, even on the highest setting!
  1. point some
    By siggylover in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2012, 01:15
  2. Thanks for the one point
    By soulman in forum General Chat
    Last Post: 27th March 2012, 08:14
  3. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  4. can someone point me to this
    By peadar in forum Engine & Drivetrain
    Last Post: 9th January 2011, 23:43
  5. Very high clutch biting point
    By NikNaks in forum Engine & Drivetrain
    Last Post: 24th February 2010, 13:46
