Results 1 to 10 of 15
Thread: changing springs on vectra c sri
    Regular Member nelly452's Avatar
    Aug 2011
    reading
    Default changing springs on vectra c sri
    hi people i'm not much of a mechanic and i want to change my springs and was wondering if it was hard or fairly easy to , any help would be appreciated
    very much , i'm just getting fed up with taking it to someone to change them for me and charge me an arm and a leg.
    Regular Member RobW's Avatar
    Tain - Easter Ross
    A garage should not charge more than about an hour to change a spring.
    As someone who had never done it before, I found it quite fiddly but I was struggling along without proper tools. The biggest part of it is to make sure you have the tools to take the nut off the top of the strut, have a look on here for peoples opinions. Vortex sockets, spark plug sockets, swan neck spanners etc.
    It is reasonably easy to do, just make sure you get good tools including a breaker bar, spring clamps and something to turn the nut and hold the strut insert.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    its not that hard to do,, the how2 on here shows you what to do and was all i needed when i first attempted mine one afternoon. If you buy them some of us can pop over and give you a hand, once you have done the once you will be able to do them again. its mainly a case of having the correct tools which is something you build up over time.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    I'd say dont do it if your in a rush, you dont wana get it wrong, the rears are a doddle coz theres no messing with shocks. The fronts take a little more time, but just follow the how2 and dont rush, you'll be sorted.
    Regular Member bigdave1701's Avatar
    York
    Going by the how2 this is quite easy.
    As for tools, being a vauxhall owner you're going to need every size torx socket & bit under the sun at some point so you may as well buy a complete kit to start with (machine mart do one for about £20) then it's just a case of borrowing spring clamps.
    Someone with more knowledge will be able to confirm this but I believe you need to have the cars tracking done once its reassembled.
    York
    East Ayrshire
    Trim : SRI XP1
    Very very easy to do. The how2 on here is very comprehensive. I just done my soon to be father in laws front spring and had it done in about 40mins, Would've been quicker but the spring compressor slipped and nearly decapitated me
    Aug 2011
    reading
    sounds a bit to tricky for me lol as i said i have no mechanical experience what so ever , would this job be quicker if the car was on a ramp ???
    Jun 2009
    South Coast
    no easier imho....
    York
    I think the only way you'd benefit from using a ramp is the time it takes to physically jack the car up.
  1. Changing springs do i need to change anything else?
    By aerodynamic18 in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2010, 22:34
  2. measurements after changing springs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 19:03
  3. changing springs
    By kenny1zero in forum Handling & Braking
    Last Post: 30th June 2008, 02:12
  4. F.A.O Any1 thinkin about changing springs
    By Penfold in forum Handling & Braking
    Last Post: 17th April 2008, 16:08
  5. changing springs
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2006, 22:45
vec c forum changing just 1 spring
