Thread: Cleaning egr
    Aug 2011
    denny
    Default Cleaning egr
    What part of the egr gets cleaned
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    The part that is all carboned up.
    You can also remove the solenoid and spring inside the black part, give it a wire wooling and a greasing up too as it can seize a bit.
    I think the doings of both of these are in the How 2 section
    Aug 2011
    denny
    Is the valve inside the barrel I could see a spring in there but did not know how to open the barrel up.I cleaned the bit underneath the barrel the nipple looking Thingy so what bit do u steep in brake fluid overnight to clean cheers
    Aug 2011
    denny
    And is it just the 2 13mm bolts u take out and unplug the electrical bit and the egr should be off cheers
  1. egr cleaning
    By hbomb in forum Engine & Drivetrain
    Last Post: 8th July 2011, 18:00
  2. cleaning help
    By davidlewis24 in forum Detailing and Car Care Discussion
    Last Post: 13th April 2009, 20:37
  3. I've ran out of car cleaning kit!
    By monkeez in forum Detailing and Car Care Discussion
    Last Post: 20th March 2009, 13:07
  4. DPF Cleaning?
    By parapaul in forum Diesel Engine related
    Last Post: 9th October 2007, 13:52
  5. Cleaning
    By thegoldenbullet in forum Detailing and Car Care Discussion
    Last Post: 11th August 2007, 22:13
