Results 1 to 10 of 18
Thread: Compressed air noise from engine under load
    Norwich
    Trim : SXi
    Engine : 2.2
    Default Compressed air noise from engine under load
    As title really, rev it and no noise but under heavy acceleration or load she sounds a compressed airline blowing. Once off the revs no noise.
    No engine lights at all and no real difference in performance but it is the first time I've driven her in 5weeks and after driving a focus anything feels quick
    Regular Member Guss's Avatar
    Aug 2011
    West Malling, Kent
    alright Mate..
    have you noiced tins of somke under hard acceleration as well?
    From my little knowledge and inexperinence it would suggest looking at your turbo pipes to and from the intercooler.....i am guessing yours is a CDTI?
    Russ
    Ashington, Northumberland
    Sounds like an intake leak under boost. Check all hoses and hose joints. You could have a holed pipe.
    Jun 2011
    Elland
    What they said.
    Now you've just got to find it
    Assuming it's a turbocharged engine...
    get someone to hold the revs at 1500 - 1800 (this should be enough to make enough boost to find the leak, but not so much engine racket that you can't hear anything!). With the bonnet up and engine cover off, start leak hunting! Use your hand to feel air escaping, too. Check and listen round the intercooler. I just did the same thing yesterday and found a leak - felt the air escaping with my hand... would have not seen it otherwise, as it was quite concealed Happy hunting!
    Norwich
    Trim : SXi
    Engine : 2.2
    Cheers guys and should have mentioned its a 2.2 dti
    Will have to wait a while I'm back working away again and can't be dealing with getting soaking wet whilst trying to find a leak!
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by the_wave_rider View Post
    Ah, thought it would be a DTi.
    Get the engine hot, bonnet up and get someone to hold the throttle down for a couple of seconds. The DTi's don't make enough boost with low revs, no load and in neutral to get the hoses to expand properly. You'll see the hoses fill up and become hard. If there's a split in the pipe, this will force it open and you should see it. Don't run your hands around the pipe though to find it. The charge air will be HOT.
    Norwich
    Trim : SXi
    Engine : 2.2
    Quote Originally Posted by cont1204 View Post
    cheers mate will try that tomo
    Regular Member Thom's Avatar
    Nov 2010
    UK
    I too have this same problem it would appear, and have absolutly no idea where the leak may be coming from, but have you found a solution wave rider?
    I admit to having tinkered with the egr/intake area so perhaps reusing old gaskets wasnt such a great idea!
    north east
    I have this and now you have mentioned it I have noticed the plastic pipe from the air box to the intake on the grill is loose / over sized might just tape it up see if that fixes the problem.
    Norwich
    Trim : SXi
    Engine : 2.2
    I found the left hand side intercooler pipe had split so ordered a new one of ebay http://www.ebay.co.uk/itm/3005908019...84.m1439.l2649 however after fitting it this afternoon it appears to be an inch too short. It only just covers the lip on the bottom tube where the pipe fit. I have now asked the seller if there has been a mistake with the cutting of the pipe. Even with this on it has made a vast difference....well it did until the right hand just split doh! Must have built up pressure and fractured the wall on the rh pipe from the intercooler and turbo.
    So I am now going to order one from here http://www.ebay.co.uk/itm/Vectra-C-T...item3a6a47a045
    I noticed with the split in mine mpg dropped drastically as did the acceleration and it smoked a lot. If you take the cover off the car you will see quite easily where it has been leaking as there will be soot all around the pipe and surrounding area.
  1. Noise under load
    By Badger Quintero in forum Engine & Drivetrain
    Last Post: 19th April 2012, 19:53
  2. load clicking noise
    By vec22direct in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2011, 13:56
  3. Weird noise under load
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2011, 22:45
  4. Ticking/Tapping noise under low rpm load
    By spatch in forum Engine & Drivetrain
    Last Post: 9th May 2008, 11:20
  5. Engine misfire? when under load
    By SYMON in forum Engine & Drivetrain
    Last Post: 15th September 2007, 15:09
compressed air ticking noise engine
