Thread: fault code 4821, what is it?
    newport
    Default fault code 4821, what is it?
    using the pedal test, think this way the number that came up, what does it mean?
    have i done it wrong? cant seem to find out what is means
    flashed on twice today for a couple of secs, then went off again
    May 2011
    bispham, blackpool
    Quote Originally Posted by taffy bhoy View Post
    are you sure its 4821 as if you read this link it will show you all codes can not find anything on 4821
    http://www.vectra-c.com/forum/showthread.php?t=19442
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    ive had a look no code exists
    if you get another code i will check it for you
    newport
    must have blinked and missed the first flash lol, its 1482, that damn cooling fan code again. happened when i first had the car, would flash on and off every now and again, nothing serious, fans kicked in when and how they should with no issues, and as soon as the bad weather stopped the light never came on again. so never done anything about it. flashforward 10mths and for no reason (was raining and on motorway) it flashed on and off twice.
    can only think it maybe a dry or damp connection, only seems to happen if really cold or wet, or i hit a bump
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    P1479 High Fan Control Primary Circuit Malfunction
    P1480 Fan Secondary Low with Low Fan On
    P1481 Fan Secondary Low With High Fan On
    P1482 SCP
    P1483 Power To Fan Circuit Overcurrent
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to troubleshooting !
    Irmscher Insignia CDTI 130
  1. Fault Code Help
    By rmg1 in forum Y & Z30DT Specific
    Last Post: 3rd October 2012, 21:12
  2. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
  3. is this a fault code
    By hoochydady in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd February 2010, 18:03
  4. Help with fault code,
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 21:57
  5. Fault Code
    By fattony in forum Engine & Drivetrain
    Last Post: 6th April 2009, 22:24
