Results 1 to 10 of 25
Thread: Brakes
    Full Member
    Jan 2008
    92 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : ....
    Year : .....
    Default Brakes
    whats the benefit - if any - of drilled and grooved front and rear discs??
    Regular Member R2XPT's Avatar
    Scotland
    Just make more noise rab, OE ftw!
    Regular Member bigdave1701's Avatar
    York
    The theory is it helps to distribute heat across the braking surface and so improve braking.
    I had them on my preface and they felt 100 times better than the stock brakes but I don't know if that's because the old ones were so badly worn the car could hardly stop!
    Scotland
    Rab save ur money for 314's standards are terrible!
    Full Member
    Jan 2008
    92 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : ....
    Year : .....
    so really they're cosmetic then????
    they look the part and thats it???
    Scotland
    Quote Originally Posted by RBH View Post
    IMO yes, I had ebc on my gsi, front and rear with red pads, they were ok, I went back to OE discs and police spec pads and braking was immense over after Market stuff, just voicing my opinion!
    York
    I'll be getting another set as and when I need to replace the bog standard set on my 1.9cdti but that's probably as much to do with liking the way they look throu the alloy.... Plus I couldn't afford a calliper upgrade.
    Engine : 1.9 CDTi
    Cheap drilled disc's can crack (Had 2 sets crack myself) but grooved disc's deglaze the pads and help remove the build up of hot gas between the pad and disc under hard breaking.
    Having said that there is no substitute for surface area so go bigger if possible,
    Scotland
    Also defo do a full brake fluid change, helps lots!
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by R2XPT View Post
    Yip your probably spot on there. However I went with drilled n grooved. the look class IMO
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
