Results 1 to 10 of 20
Thread: urgent help needed please. automatic window
    Regular Member amir2300's Avatar
    london
    confused urgent help needed please. automatic window
    ASAP help needed
    Is there a way I can manually close the front electric window?
    The drivers side window is open and will not close. I can hear a click sound when I press the up button and everything else works on the control module.
    the key button only now closes the passenger side window.
    Need some urgent help please guys
    Ps its 2007 1.9 (120)
    me, i would take the door card off, disconnect the glass from the feed rail and wedge the glass up tight and replace the door card till you can get to a garage and get it sorted out...
    micky,...
    london
    Thanks, How easy is it to do that? I am miles away from home and have to do this in a petrol station somewhere.
    i am realy not sure, but im sure it cant be that hard,
    door panel removal..http://www.vectra-c.com/forum/showthread.php?t=15087
    after that mate, i cant realy help, its been along time since i did anything wiv vec c windows, ..sorry mate..
    check out this mate...http://www.vectra-c.com/forum/showthread.php?t=92625
    london
    Thanks mate, not sure I can do that at the side of the road.
    london
    Do you know if there is a manual way of putting the window up?
    no idea, sorry mate
    Regular Member Shogun's Avatar
    Aug 2011
    Long shot but does your breakdown cover or anything cover it??
    Wish I cud help mate but I'm clueless, on my old car it jammed (not vaux) and I peeled the rubber back a bit and managed to pull it up
    hope u get home safe mate
    Jul 2009
    The Rift, Cardiff
    There's many possibilities for whats actually broken, so there's many possible methods for securing the glass in the closed position. But taking the door card off is the first step.
    If the motor or it's mech has gone you might be able to lift the glass then use mole grips to clamp it as high as possible (i did this on a mates high&dry accent).
    If one of the cables has snapped, again you may be able to lift the glass (you might need to give it slack by pressing the up button).
    But if a cable is jammed it's allot more involved. I did a temp fix on my mates vito last week that had a jammed and frayed cable, i had to release the glass from the clamps and remove one of the runners/guide rails to untangle the cable. Then refit so the cable could operated by hand to pull up the glass (helper very usefull here), then i tied it off and secured with a section of connector block/chocolate block.
    As far as I'm aware there is no manual override.
    how did u get on mate ?
  1. Manually Operated window to Automatic.
    By 123rado in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2010, 21:30
  2. Automatic headlight leveller help needed
    By leeroberts919 in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2010, 17:01
  3. Automatic window problem
    By musaban1 in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2009, 06:15
  4. urgent help needed!!!!!!!!!!
    By johnnyg in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2008, 14:29
  5. urgent help needed
    By LISAJANE0410 in forum Suspension, Wheels & Brakes
    Last Post: 29th June 2008, 15:21
