Thread: P0380
    Jul 2011
    UK
    Default P0380
    When cold starting (and not every time, but most) the spanner light comes on and goes out after a few minutes. Does not happen at startup when the engine is warm/hot. Driveability is not affected.
    I read the code earlier and it came back with 'P0380 (B) Glow Plug Circuit Not Present'. Having browsed around on here, i see it could be plugs, temp sensor? or relay/control unit, all of which I have no idea of location!!
    Any one any ideas? Its on the 2.0dti Zafira; not a vec I know but its the same engine....
    Regular Member benny's Avatar
    Feb 2006
    dudley
    glow plugs ...
    Jul 2011
    UK
    Thats what I was afraid of, I've heard the horror stories about snapping and threading etc. What is the torque setting for tightening them back up? Can get a set a denso set for about £12 each from ECP.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    10Nm/7lbft,you will have to remove the charge air pipe.hose clamp is 3.5Nm (no more)be carefull with the gasket.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by ijk571 View Post
    What about these NGK usually good for the job http://www.ebay.co.uk/itm/NGK-Glow-P...#ht_926wt_1139
    Jul 2011
    UK
    Thanks, they are bit cheaper, and a good make too. Cheers for the info. I've added them to my watchlist.....
  1. Help error code P0380
    By tomo610 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2012, 20:57
  2. P0380 Code
    By WeDesign in forum Engine & Drivetrain
    Last Post: 9th January 2012, 23:14
  3. P0380 Fault Code
    By fattony in forum Engine & Drivetrain
    Last Post: 12th December 2011, 01:15
  4. P0380 Error where are the plugs on the 1.9 120
    By slipperysam1984 in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 15:53
  5. p0380
    By redross555 in forum Engine & Drivetrain
    Last Post: 17th September 2011, 17:41
p0380 zafira b 1.9 cdti
