Thread: Heeeeelp me please 1.9cdti - changed thermostat now limp home!!
    Aug 2011
    Just outside Lincoln (so stuck in traffic!)
    Engine : 1.8 vvt
    Mileage : 67000
    Default Heeeeelp me please 1.9cdti - changed thermostat now limp home!!
    Please help guys,
    I just replaced the thermostat on my 1.9cdti (120), its gone from not heating up at all to going upto 85 degrees and having no power and not revving above 3200 rpm.
    Only thing i can think of is i removed the vac pump. when i re-attached it i forgot a screw and oil was 'drooling' out, as soon as i noticed it(just idling the engine, hadn't driven it yet).
    I guess its off to vx as i dont have opcom and the paperclip test doesn't work.
    Help me i cannot afford this
    Dan
    Regular Member bigdave1701's Avatar
    York
    Have you checked everything you'd un screwed has been properly tightened and no hoses are only 1/2 on? If all that's fine then try disconnecting the battery for 15 mins to allow the ecu to reset. If that dunt work I'm out of ideas.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    vac system leak or a faulty vac pump ....did you blled the coolant system after fitting ? ...
    Aug 2011
    Engine : 1.8 vvt
    Mileage : 67000
    not sure on the bleeding thing, i ran it and i got hot air from the vents , i thought it was anti-airlock
    As for the pipes i cant see anything loose and ive checked 3 times now. :-(
    Regular Member brotherkennyh's Avatar
    Swadlincote
    do you get limp home mode straight away or only as the car comes up to temperature?
  1. egr blanked - 2000 miles and no limp home home
    By jonestown in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 14:55
  2. Changed the thermostat on 3.2 but...
    By Liam_S86 in forum Engine & Drivetrain
    Last Post: 13th February 2012, 23:13
  3. Thermostat Changed...... :)
    By Meady in forum Engine & Drivetrain
    Last Post: 10th March 2011, 14:22
  4. Changed thermostat and...
    By Ricksh in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 17:40
  5. thermostat changed today
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 6th February 2010, 16:00
