Thread: Passenger Window
    Mar 2011
    Surrey
    Default Passenger Window
    Hi guy
    My friend has a vectra c preface lift
    His issue is when he tries and put the window up it'll take a good few pushes to get up.
    Going down is not as much a issue but does judder abit.
    Any advice before I take the door card off.
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    i have used back to black on the rubbers as they sometimes go hard and grab the window
    Regular Member Innes's Avatar
    Plymouth
    It sounds like his contacts need a clean in the switch. Look in the HOW2 section for it.
    Jul 2009
    The Rift, Cardiff
    As said above check the condition of the rubber. Could also be that the runners need greasing.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Sounds like a mixture of both issues...
    Difficulty getting the window to respond to the door switch, is a dirty switch contact.
    Dismantle and clean the switch innards to restore service.
    Juddering movement of the glass sounds like the seal strips dragging on the glass.. quick clean and lube will sort this... back to black or a rubber conditioning solution should help with this.
  1. passenger window help please
    By yadziyad in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2010, 21:57
  2. Passenger window controls?
    By strothrc in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2009, 20:17
  3. passenger window goes down on its own ??
    By tonyord in forum Bodywork & Interior
    Last Post: 2nd April 2009, 20:54
