Thread: Parking sensors aaaahh!!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Parking sensors aaaahh!!
    Ive had gadget man front & rear sensors for some time & Ive had a replacement main box cos i thought it was that, But this annoying peeep! is doing my head in, Ive changed the earth wire/disconnected each sensor & all sensors and after the sensors have been activated i still get this intermittent peeep, It seems like some kind of power bleed back or shorting that's giving me this problem
    Engine : 1.9 CDTi
    Where is the box located?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The box is in the left cubby hole in the boot, My first box got water inside so i dried it out i (think this was when it started playing up) a new box was sent & it seemed ok for a while but ive tried everything i can to solve this! with no luck, (by the way my new box has had a rubber glove covering it from new so 'no water' ??? re done the earth & moved to another point just in case.
    Jul 2009
    The Rift, Cardiff
    Could it be extra sensitive to the bulb-check pulse? Maybe fitting a relay between the reverse light wire and the control box will solve it.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    newport
    i fitted mine today on the drivers side of boot, keep it away from the fuse box and bits, i know things like that can be very sensitive to things around it
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by ChrisBilly View Post
    Any ideas what/where the item i could use, its so annoying i usually pull the power wire on long journeys as it just keeps peeep'ing all day long!, Ive even tried just having the front or rear set connected & it still does it!, done a 3/12 hr drive the other day & iit done it all the way!.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Right might be getting somewhere 'hopefully', Had another look after the wife said don't talk to me 'about sensors', Seems she's had a lot of peeep's from them this morning!, So I've moved the earth 'yet again' (first it was at the same place as the others at the bottom of the LH light cluster low down, Then i put it on the body/bolt for the light, Now just messing i stuffed the connector between the alarm siren & its metal bracket holder (15 mins test & no sound) so ill go in it to work later & see.
  1. OE Parking sensors
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2012, 19:02
  2. Parking Sensors
    By Mark2.2 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 21:01
  3. HELP parking sensors
    By lee11 in forum Troubleshooting
    Last Post: 4th December 2009, 13:38
  4. New parking sensors
    By larrysSRI in forum Bodywork & Interior
    Last Post: 27th November 2009, 06:38
  5. Parking Sensors! Help!
    By Schui1024 in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 23:52
