Thread: help needed...how do you compression test a z22se engine
    Regular Member Miketwinny's Avatar
    Sep 2009
    St.Helens, Merseyside
    Post help needed...how do you compression test a z22se engine
    how do you compression test a z22se engine.
    thanks
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Remove each injector in turn fitting gauge as you go. Get someone to crank a couple of times whilst you note the readings.
    Then drop a small amount of oil down each hole an perform again see if there's any change.
    An electrical compression test can be carried out on diagnostics. But I wouldn't souley rely on them
    Quote Originally Posted by CritchvxD View Post
    Don't you mean spark plug?
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    Would have thought so
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Same difference. I work on diesel trucks but was only for a rough idea for him
  1. Compression test results on Z22YH......
    By Nik in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 14:09
  2. Engine Compression
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2010, 22:00
  3. compression z22se
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 20:56
  4. compression test 2.0 dti
    By dan9895 in forum Engine & Drivetrain
    Last Post: 23rd September 2008, 13:53
  5. Replies: 2
    Last Post: 2nd April 2008, 18:34
