Thread: Heads-up V6 CDTI split hose location
    Jun 2011
    Elland
    Default Heads-up V6 CDTI split hose location
    Found this split on the rigid pipe that feeds air to the throttle body
    [img]
    [/img]
    http://s1135.photobucket.com/albums/...ent=split2.jpg
    Ordered replacement part from VX - £70 inc VAT.
    Strangely it has not thrown any codes... just noticed it down on power a bit and hissing
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Bless the old Y30DT and its aluminium manifold
    Regular Member robster23's Avatar
    Hastings
    Thanks for the pic. Can you just say where that is in the engine bay, is that taken from underneath? Many thanks.
    Jun 2011
    Elland
    Hopefully the second pic link works - it gives a clearer idea than the close-up. It's the rigid pipe that goes to the throttle body right at the top of the engine. You need to take the engine cover off to see it. The split is just visible if you look just down fron the jubilee clip and is in the rigid plastic pipe itself.
    Very hard to spot if you did not know what to look for, but I used the engine cover (jammed in the drivers footwell) to hold the revs at 1500 and nipped round to the engine to have a look. Could hear the hissing and only spotted the leak when I felt the air with my hand
    The part has to come from Opel - stealers had not heard of one going in that place before. Just a useful mental note to have as a 'location of possible failure' when looking for splits in the system
    Another point to note is to check the actual union between the rigid pipe and the throttle body - mine came loose and was losing boost under high boost conditions: the joint looked normal until I wiggled it! I tightened the jubilee clip and all fine... but I suspect there is quite a bit of vibration in this joint area which firstly: caused the joint to work loose and secondly: with the joint tightened up, caused the split.
    I will have to keep an eye on the new part when it arrives: if it fails again, a 'home brew' alternative will have to be found - PITA, as there is a sensor in that rigid pipe!
  1. Split hose
    By s2yob in forum Engine & Drivetrain
    Last Post: 20th September 2011, 19:49
  2. turbo or split hose??
    By jsnlvxr in forum Engine & Drivetrain
    Last Post: 8th November 2010, 17:54
  3. split hose
    By SB3871 in forum Engine & Drivetrain
    Last Post: 7th July 2009, 14:46
  4. Split Turbo Hose
    By Batesie in forum Diesel Engine related
    Last Post: 22nd May 2007, 16:43
  5. split in hose
    By bentleyboy in forum Engine & Drivetrain
    Last Post: 12th October 2006, 17:54
